8 Pages V   1 2 3 > »
> Steering wheel swap guide, this is not common "how-to" but just small guide...
post Jan 6, 2007 - 4:04 PM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
At last I had some time for another upgrade. Steering wheel swap... My stock one was 4-spoke with airbag/horn in the middle.
Just history now biggrin.gif. Since today I have this one wink.gif genuine 7th gen. Celica/91-04 MR2 st. wheel.
Although horn mechanism and airbag connector were different everything is working now. And I'll try describe here how generally do that... believe it will be handy for anyone wink.gif
step no one: remove old steering wheel
Two screws on sides (behind small covers) holds airbag part
There are just two plugs inside. That yellow one is for airbag and white is horn (there is possibility also for cruise multi switch, where are many more wires. Horn wire is black, every time that last on right connected to wheel body)
When you unplug everything + unscrew nut in the middle you should remove wheel with puller (w/o that it's not possible at all)
step two: solving airbag connection
Different airbag connector means find right module (spiral) for it...
Of course... some customization should be done if airbag refill has different size (more are different, more custom work is needed). My one was just bit different... and airbag part was easy take into parts.
step three: solving horn connection
This step depends on type of horn you have. However every time it's about find how horn mechanism works, cut black wire off old wheel and connect it somewhere... It really depends on that horn mechanism. However it's really easy, just one wire to screw... somewhere wink.gif.
step four: piece everything together
Installation of new wheel body (with same center bore of course) is easy...
...and in my case screw horn cable to airbag body (not wheel body like stock one)...and all finished biggrin.gif.
This post has been edited by malpaso: Jan 6, 2007 - 4:27 PM
post Jan 6, 2007 - 4:16 PM
snapshotgt
Joined Oct 12, '05
From Texas
post Jan 6, 2007 - 4:18 PM
zCelicaDude
Joined Nov 20, '06
From Auckland, New Zealand
very nice guide. this will be very helpful to the 6gc community. thanks!
post Jan 6, 2007 - 7:46 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
nice i like it a lot. How much did you get the stearing wheel for?
IPB Image <--- I miss :'' (
post Jan 7, 2007 - 12:35 AM
post Jan 7, 2007 - 2:39 AM
malpaso
Joined Feb 3, '06
thanks for posts and PMs. Here is additional info:
7th gen/MR2/MR-S st. wheel. Where and how much?: I have that st. wheel from e-bay for 250USD (here is another one, red stitched wink.gif)
Why not "how-to article"?: Yes, this should be "how to swap 7th gen st. wheel" article, but only for Euro models. Thanks to snapshotgt I know you have bit different wiring in US (because of that cruise control switch). Euro celicas don't have that at all... That means in US you must swap also that switch -> customize body of that new wheel (cut some hole or anything) and mount it somewhere (some screws in right place???). That's why I rather call it "guide" wink.gif
Is airbag really works? Are you sure?: Yes, airbag really works. When you turn keys on, every time runs "airbag-check" (airbag control light on for a while). If it's something wrong with check, control lights all the time. That's why I'm sure... Of course second way to prove it is crash biggrin.gif.
Do you have part # of that 7th gen module? Will it work in 6gen celi?: par number is not problem wink.gif 84306-32030. And, no I'm not sure it will work with 6gen celica... frown.gif. I don't have that module (I didn't want to spend another 50USD), it's just a general option and possible way to try.
post Jan 7, 2007 - 4:55 PM
tomazws
Joined Oct 30, '04
From So Cal
Nice swap dude! That 7th gen steering wheel looks 100x better!
post Jan 7, 2007 - 10:53 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
aww. i guess i wont be doing it. US import cars are gay.
post Jan 7, 2007 - 11:19 PM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
Excellent work, congrats!!!!
This post has been edited by Rockford: Jan 7, 2007 - 11:20 PM
Celica ST202
post Feb 10, 2007 - 9:19 AM
CelicaSweden
Joined Oct 14, '06
From Sweden
Which size is the puller?
100mm, 150mm or 200 mm ?
Need to know asap because Im removing my steering wheel right now : )
post Feb 10, 2007 - 10:43 AM
malpaso
Joined Feb 3, '06
QUOTE(CelicaSweden @ Feb 10, 2007 - 3:19 PM) [snapback]525678[/snapback]
That one I have is 3'' (cca 76mm)
post Feb 11, 2007 - 3:16 AM
CelicaSweden
Joined Oct 14, '06
From Sweden
QUOTE(malpaso @ Feb 10, 2007 - 10:43 AM) [snapback]525686[/snapback]
okey, is that a speciel one for just our celi or is it a universal tool ?
post Feb 11, 2007 - 3:28 AM
malpaso
Joined Feb 3, '06
QUOTE(CelicaSweden @ Feb 11, 2007 - 9:16 AM) [snapback]525876[/snapback]
universal one bought in local store...
post Feb 11, 2007 - 11:18 PM
Excursion745
Joined Feb 10, '07
From West Springfield MA
7th gen/MR2/MR-S st. wheel. Where and how much?: I have that st. wheel from e-bay for 250USD (here is another one, red stitched )
Now what if i took out the cruise control.. does that mean i dont need to mod the new wheel or do i still need to put that dead switch in the new wheel???
post Feb 12, 2007 - 2:29 AM
malpaso
Joined Feb 3, '06
QUOTE(Excursion745 @ Feb 12, 2007 - 5:18 AM) [snapback]526071[/snapback]
If you will remove cruise control (that means you will not use it in your car anymore) you should do same steps like I did, plus:
1. remove cruise control switch (for sure it should be removed)
2. modify wiring harness (same plug is used for horn and cruise control switch -> you must cut anything but horn).
For example:
In picture below is plug (white, bottom of picture) and 4 wires. White, white+black-stripe, red, black. That black is horn (must stay) rest you should cut, because those are wires for cruise.
that's all
post Feb 27, 2007 - 10:56 PM
I was lucky enough to get my hands on some 7th gen parts at a good price biggrin.gif
from this
and about an hour later this
sorry about the night pic, but I just finished. I'll get some day pics tomorrow or so.
Martin, the way I did it was easier than the way you did - no airbag repacking, just a splice here and there wink.gif also, I used the 7th gen cruise switch (it's wired different than the 6th gen) so I'm 99% sure it works, I just need to road test it.
post Feb 27, 2007 - 11:13 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
nice. now i'm really thinking about doing this mod. what did you do different from martin's how-to?
post Feb 28, 2007 - 1:43 AM
malpaso
Joined Feb 3, '06
QUOTE(Batman722 @ Feb 28, 2007 - 4:56 AM) [snapback]531085[/snapback]
I'm glad someone had all parts from 7th gen (particularly 7th gen module/spiral) and made it different way...
So, am I understand right, you have used that module and it works even with cruise control??? More info please!!! smile.gif
post Feb 28, 2007 - 8:52 AM
the 7th gen clockspring (spiral) does not fit in the 6th gen. I simpily cut the connector off the 7th gen spiral and used it on my 6th gen one. Both have 2 wires, blue/black and yellow. It made the swap a 15-30min job. As for the cruise it get's a little tricky. The 7th gen switch has 2 wires from it (red and white) and the 6th gen has 3 (red, white, and white w/black stripe). You just have to find the right combination of 2 wires. I tried a few before I got it, I think it was w/bck to white, and white to red (from 6 to 7)
post Feb 28, 2007 - 9:30 AM
malpaso
Joined Feb 3, '06
QUOTE(Batman722 @ Feb 28, 2007 - 2:52 PM) [snapback]531202[/snapback]
the 7th gen clockspring (spiral) does not fit in the 6th gen. I simpily cut the connector off the 7th gen spiral and used it on my 6th gen one. Both have 2 wires, blue/black and yellow....
yea... but you have 50% chance to connect it bad an deploy it wink.gif. Any way to be sure which one is which?
I had black/red on 7th gen and red/red on 6th gen... kindasad.gif
This post has been edited by malpaso: Feb 28, 2007 - 9:31 AM
8 Pages V   1 2 3 > »
Lo-Fi Version Time is now: April 20th, 2025 - 3:23 PM
