8 Pages V  « < 5 6 7 8 >
> Steering wheel swap guide, this is not common "how-to" but just small guide...
post Nov 10, 2012 - 7:02 PM
sr666
Joined Jul 31, '12
From England
As above a massive thank you to Malpaso for popping this up and everyone else's input is appreciated smile.gif
I've only got one small issue is that on the UK spec GT (early 95) I've not got the yellow spiral connector but my horn doesn't work. is it just a case of finding the black wire and extending it then attaching to the gen 7 wheel?
This post has been edited by sr666: Nov 10, 2012 - 7:03 PM
post Nov 11, 2012 - 4:10 AM
Nihil
Joined Jul 17, '12
From Slovenia
Got any picture of how it was connected to your previous wheel? Surely there isn't some rocket science behind the horn connector, can't be anything more than a single wire that makes a negative contact when pressed
post Nov 12, 2012 - 7:10 AM
sr666
Joined Jul 31, '12
From England
You'd think it'd be simple but in the ones shown there there's the yellow spiral adaptor on mine there isn't one. I couldn't see a black wire else it'd be simply just a case of extending the wire back to the bolt (not the centre spline) which would attach the wheel to so when the horn is pressed the circuit s complete surely?
post Nov 12, 2012 - 9:18 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
QUOTE (sr666 @ Nov 12, 2012 - 4:10 AM) *
The harness that goes from the clock spring to your cruise control also handles the horn. There would have been a black wire that was riveted to the internal spring structure of the stock wheel. You need to cut that wire off of the stock wheel and put an end on it that will allow you to bolt it to one of the four nuts on the airbag explosive.
**** Photobucket
post Nov 12, 2012 - 11:35 AM
sr666
Joined Jul 31, '12
From England
QUOTE (95CelicaST @ Nov 12, 2012 - 9:18 AM) *
That's fine but I've not got cruise I'm in a Euro model lol. Cheers I'll have another look when I remove the wheel again smile.gif
post Nov 12, 2012 - 12:04 PM
95CelicaST
Joined Feb 5, '05
At the very least there should be (or should have been) a black ground wire attached to the old steering wheel. You just need to find where it went, and hook it to the back of the 3-spoke wheel's explosive.
**** Photobucket
post Nov 12, 2012 - 12:10 PM
sr666
Joined Jul 31, '12
From England
Perfect cheers I'll have another looksie.
post Jun 26, 2013 - 1:42 PM
Syaoran
Joined Jan 4, '12
From US
Back from the dead:
You'd think that after so many years of posting you'd see the actual size of the torx bit mentioned by someone. XD
Anyone know what the torx size is for the 2 bolts?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jun 26, 2013 - 3:34 PM
richee3
Joined Jun 29, '08
From Denver
T27 if I recall correctly.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 26, 2013 - 9:27 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (richee3 @ Jun 26, 2013 - 4:34 PM) *
Thanks I'll check it out when I get my wheel.
post Jun 26, 2013 - 9:45 PM
richee3
Joined Jun 29, '08
From Denver
They're either T27's or T30's. I'm leaning towards T27's. Which steering wheel are you going with?
1998 Celica GT-
BEAMS Swapped.
post Jun 27, 2013 - 1:44 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (richee3 @ Jun 26, 2013 - 10:45 PM) *
Nothing expensive. Bought a replica from a local shop. Waiting for it to arrive to pick it up. I think it's an NRG replica not sure.
post Jan 21, 2014 - 6:34 PM
saleenvic
Joined May 3, '12
From Northern VA
QUOTE (GriffGirl @ Feb 16, 2010 - 3:50 PM) *
QUOTE (shegarhuney @ Jan 18, 2010 - 2:34 PM) *
no more fuss.. the missing link ladies n gentlemen..
QUOTE (FORGMANN @ Jan 17, 2010 - 1:44 PM) *
you don't need to splice any wires just buy this adapter
have to order from here not your dealer ..
http://toyota.spx.com/detail.aspx?id=407&p=173&g=21
Just thought I'd update this with my own findings, I was able to order this part off of http://www.handsontools.com/; prior to ordering I emailed to confirm part is in stock - part is in stock and will ship within 48 hrs. Part costs $16 on this site, but shipping is a bit high at $10 for UPS ground.
Edit: sub-"herness"? lol
Hey whats up everyone,, got a quick question, I am in the middle of this swap,, got the cruise control squared away so I'm just left with the airbag connection. For those of you who have done this swap with this subharness,,,does it really make a difference, meaning no srs airbag light on? I don't mind splicing wires n what not but if i know that this subharness will not give me any code issues off the bat then I'd feel more comfortable about shelling out $40 bucks,, (shipping is pricey) Any input at all greatly appreciated, thanks again for all you who have contributed to this topic.
This post has been edited by saleenvic: Jan 21, 2014 - 6:35 PM
post Jan 21, 2014 - 10:35 PM
ok it depends on what u want. you can get this adapter, you can splice the harness or you can buy the clock ring.
the clock ring part n0 84306-12070 it came in various cars and can be had for cheap en ebay and yards. ravs, camrys, some lexus.
I am going to get the appropriate part because just in case I ever sell the car, but mostly ill be more content.
post Jan 22, 2014 - 11:59 AM
saleenvic
Joined May 3, '12
From Northern VA
QUOTE (njccmd2002 @ Jan 21, 2014 - 11:35 PM) *
Thanks for the reply back. I was reading that those that did this swap were getting the SRS airbag light on right, and were having to reset the airbag ECU to get the code to clear. I haven't connected the airbag yet,, but whether I go with splicing the wires or the harness adapter, if i get the airbag light on I can just remove the code with a OBD II scanner correct, to eliminate it,,, or do either way I need to reset the airbag ECU no matter what route I choose?
Just calculating my next step lol.
post Jan 22, 2014 - 12:21 PM
ok, when i did mine, never got the airbag light on. and I spliced mine,
it is when i did my swap, that i ran the car with no airbag, that i got the code.
so maybe people hooked the batteries while they car the car with no bag..
post Jan 23, 2014 - 8:46 AM
Nihil
Joined Jul 17, '12
From Slovenia
I also spliced the wires and never got any airbag issue... SRS light comes on with the key turned, stays on for about 5 s, and goes off... just as it did on the 4-spoke wheel.
Using this harness might be a good idea if you feel that you will someday switch back to your stock wheel.
post Jan 23, 2014 - 12:02 PM
saleenvic
Joined May 3, '12
From Northern VA
QUOTE (Nihil @ Jan 23, 2014 - 8:46 AM) *
I appreciate the feedback guys, thanks.
post Apr 7, 2014 - 7:58 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Got mine in thanks to this post and others for helping me out.
post Apr 13, 2014 - 6:22 PM
ILoveMySilly97
Joined Mar 8, '12
I'm a visual guy so this MR2 steeringwheel swap would've been MUCH better help.
http://www.youtube.com/watch?v=nndrnsq0DvU
Lo-Fi Version Time is now: February 17th, 2025 - 2:17 AM
