> FULL EXAUST SYSTEM, WHATS BETTER
post Jan 6, 2007 - 5:55 PM
xxFROZENxx
Joined Nov 13, '06
From AUSTRALIA(MELB)
hey guys im jux wondering if u guys know if i buy 4-2-1 extractors with a 2.5 inch exhaust system would i lose power becoz of the 2.5 inch system or would i gain power??? alot of people say that my celica is recommended 2 inch system, but i tink its a load of crap... so i need help on my exhaust system u guys r the experts so can u pls help give me some feedbak??? i have a 1995 celica sx 2.2.. tanks guys
post Jan 6, 2007 - 6:09 PM
94_st_hatchback
Joined Mar 15, '06
From Long Beach
idk for sure, but i hear it will barely add power, like 2-5hp..
" i don't work for toyota, i work for my toyota. "
post Jan 7, 2007 - 2:26 PM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
using this graph from what appears to be a textbook or something, a 2" diameter exhaust is plenty for the amount of horsepower our car has
post Jan 7, 2007 - 2:57 PM
haha thats the scan I made from the book by Corky Bell....
but a 4-2-1 header with a 2" exhaust would be completely sufficient for any celica
with a 2.5" exhaust you'll be loosing some overall efficiency as if compaired to a 2" exhaust...though you will be loosing power due to your exhaust not because of the header
overall judgement....listen to your friends 2" > 2.5"
post Jan 7, 2007 - 3:12 PM
ExSane
Joined Apr 17, '06
From under your bed.
Yeah, I was thinking the same thing. 2.5" exhaust is a little too big. I know you don't like seeing a small exhaust pipe but still, remember the old saying, "It's not the size that matters. It's the motion of the ocean." LoL. Meaning the flow of the gas pulses and the pressure to keep them in one will make you gain horses. "Exhaust gas does not come out of the engine in one continuous stream. Since exhaust valves open and close, exhaust gas will flow, then stop, and then flow again as the exhaust valve opens. The more cylinders you have, the closer together these pulses run. Keep in mind that for a "pulse" to move, the leading edge must be of a higher pressure than the surrounding atmosphere. The "body" of a pulse is very close to ambient pressure, and the tail end of the pulse is lower than ambient. It is so low, in fact, that it is almost a complete vacuum! The pressure differential is what keeps a pulse moving."
This post has been edited by ExSane: Jan 7, 2007 - 3:12 PM
post Jan 7, 2007 - 6:24 PM
xxFROZENxx
Joined Nov 13, '06
tanks guys but do you guys know of any muffula dat gives you performance and not too loud???
post Jan 8, 2007 - 1:19 AM
ExSane
Joined Apr 17, '06
QUOTE(xxFROZENxx @ Jan 7, 2007 - 6:24 PM) [snapback]515952[/snapback]
post Jan 8, 2007 - 2:34 AM
xxFROZENxx
Joined Nov 13, '06
u guys know of any place where i can buy it in Australia or i i have 2 order it from overseaz
post Jan 8, 2007 - 11:25 PM
ebay
go buy a universal magnaflow muffler and have a local muffler shop make you some piping and install it
This post has been edited by playr158: Jan 8, 2007 - 11:26 PM
post Jan 9, 2007 - 1:50 AM
Ratix240sx
Joined Oct 17, '06
From Jacksonville
I've never heard of 2.5 inch exhaust loseing power, maybe its a because I'm 240 guy and run a 2.5 inch exhaust on my NA KA.
post Jan 9, 2007 - 6:01 AM
creis
Joined Jan 10, '04
From Shoreline, WA
ebay
exactly
post Jan 12, 2007 - 2:32 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
LOL, the thought of putting on a muffler to add horsepower cracks me up. Anyway, 2" would be perfect, given that we don't have the most powerful of engines around, we aren't pushing that much exhaust, with 2.5" you'd have to wonder about a little bit of back pressure which would be bad. Just remember to keep everything "flow flow" and you'll be fine. Recommending a high flow Magnaflow Cat and Muffler. Also if you don't want it too loud you can add a resonator in the line.
post Jan 12, 2007 - 4:46 PM
pokemeintheeye
Joined Sep 27, '04
From Minnesota
2" exhaust system better? Isn't the stock exhaust piping 2.25"? So going smaller is better? Doesn't make sense to me.
post Jan 12, 2007 - 5:45 PM
stock = ~1.75
post Jan 12, 2007 - 6:49 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Yeah stock is def smaller than 2". However if you drive a GT you could effectively go with a 2.25" if you want a deeper sound. You should talk to a local exhaust shop I'm sure they'd be happy to answer any questions you have if you want a professional opinion.
post Jan 12, 2007 - 7:22 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
I run a 2.5" custom exhaust system (over-axle) and surprisingly it improved acceleration, but that's just me smile.gif
This post has been edited by netrata: Jan 12, 2007 - 7:30 PM
post Jan 14, 2007 - 5:17 PM
pokemeintheeye
Joined Sep 27, '04
From Minnesota
QUOTE(playr158 @ Jan 12, 2007 - 10:45 PM) [snapback]517446[/snapback]
stock = ~1.75
Huh? Seriously? Man, I've always thought 2.25. 2 inches sounds real small to me though for an exhaust system. My custom catback is 2.25 though. I don't notice any loss in power.
post Jan 15, 2007 - 10:11 AM
Kadett
Joined Mar 17, '05
From The Netherlands
2,25" is the stock diameter of the ST205
post Jan 16, 2007 - 12:57 AM
xxFROZENxx
Joined Nov 13, '06
thanks for all ur feed bakc guys it was really help full.
Lo-Fi Version Time is now: February 19th, 2025 - 3:10 AM
