Enthusiast ![]() Joined Dec 3, '05 From San Jose, CA Currently Offline Reputation: 0 (0%) ![]() |
u know how the st (7afe) has the rpms at like 3.5k-4k in 5th gear cruising at 80mph? well how are the rpms in a 3s swapped car while cruising at 80? hopefully not at 3.5-4k like in the gt and st right?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) ![]() |
isn't this tranny related and not dependant on the engine?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) ![]() |
With the e153 around 65 mph is 3k rpm's.
QUOTE(Rjb23 @ Jan 7, 2007 - 10:08 PM) [snapback]516000[/snapback] With the e153 around 65 mph is 3k rpm's. i think thats the same with the tranny that comes in the st...so then does the top speed not increase with the swap by much? |
I've had mine up to 115 before and I could have kept going easy. I don't think I was above 5500k rpms.
well wut about with the 3sge, 1mzfe, and gt trannies? anyone know?
oh and sry i originally posted this topic in the wrong section. This post has been edited by hashmaster52: Jan 11, 2007 - 12:12 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) ![]() |
If i am not mistaken, my GT tranny (3sgte swap) is around 3k at 65mph give or take a couple hundred.
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(MaskedMan @ Jan 7, 2007 - 7:06 PM) [snapback]515998[/snapback] isn't this tranny related and not dependant on the engine? You will just have to find the ratios for your particular transmission to figure out the RPM at a given speed. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
go here, left is S54 right is E153.
then play with the Rev limit and it graphs everything and gives you detailed info on top speed in each gear. im surprised at how 1st-3rd are almost identical. -------------------- |
Lo-Fi Version | Time is now: February 19th, 2025 - 11:09 PM |
