> brake problem
post Jul 9, 2003 - 2:14 PM
DoodieHead
Joined Mar 31, '03
From Bowling Green, KY
when i'm going 45+ mph and if i push in the brake, the brake sometimes goes in half way and then finally starts braking. i lift off the brake and push back in and its fine. anybody know what the deal is? i dont think i should drive the car til i get it fixed even tho i just got new clutch frown.gif
post Jul 9, 2003 - 2:50 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
1. your brakes are probably waisted already and you need new ones.
OR
2. your break line are probably leaking oil
This post has been edited by sphinx_race911: Jul 9, 2003 - 2:51 PM
post Jul 9, 2003 - 3:41 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
Sounds like it could be a leak. Don't drive it until you get it fixed!!!!!!!!!!!!!
could also be air in the lines or a seized caliper?
ghostdog
From ny to philly
did you try changing your brake fluid and bleeding the line?
post Jul 9, 2003 - 4:09 PM
sphinx
Joined Apr 10, '03
yeah, thats the first thing you should do. fill it up and bleed them.
post Jul 9, 2003 - 4:52 PM
true4form
Joined Apr 1, '03
From Wilmington, DE
Might be the master cylinder goin', that's what happened to mine a year ago.
It feels like its not catching the brake and eventually it feels like you're sliding on ice.
Glad I have a 5spd, I learned to downshift real quick after that. Got to the point where it was just about the only way to stop the car.
post Jul 9, 2003 - 5:22 PM
DoodieHead
Joined Mar 31, '03
first thing im goign to do is bleed it, if doesnt work, i might check out the master cylinder, bc thats what mine is exactly doing
post Jul 9, 2003 - 7:44 PM
true4form
Joined Apr 1, '03
From Wilmington, DE
I wonder if mechanics are doing something wrong, because my master cylinder went right after i had my clutch replaced also... (like a week later)
post Jul 10, 2003 - 4:46 AM
DoodieHead
Joined Mar 31, '03
no, it was doing it before i replaced clutch, other owner didnt replace old clutch right tho, he claimed it was put in 10,000 miles before i bought it, and clutch went out after me driving it for about 10k miles. they didnt resurface or anything and left bolts missing. fixed all that when i got new clutch (my father owns his own business)
Lo-Fi Version Time is now: February 16th, 2025 - 7:57 AM
