Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) ![]() |
Where can I get the clips to hold down the rubber gasket around headlights? It seems I'm missing some.
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(DmVinny @ Jan 12, 2007 - 9:55 PM) [snapback]517497[/snapback] Where can I get the clips to hold down the rubber gasket around headlights? It seems I'm missing some. You can just swing by your local Toyota Dealer and order some. Shouldn't cost you that much. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) ![]() |
toyota doesn't sell those little clips individually. I've tried it already. I think you have to end up buying the headlights again or hit up a junkyard.
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) ![]() |
i used some emblem glue n just glued the gasket around mine - i plan to get projectors some enough after i get my engine in so if ya still need/want clips then id give em to ya =)
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
![]() ![]() ![]() ![]() (2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 1, '04 Currently Offline Reputation: 1 (100%) ![]() |
mine were loose too...
in fact one day one of them was just gone... ![]() Meh... theyve been out for almost a year and a half... maybe longer... and nothings happened... -------------------- ![]() 2003 Nissan Murano SE |
![]() Enthusiast ![]() ![]() Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) ![]() |
i used some silicon seal in place to hold them in.
-------------------- My Celica Is Now For Sale
![]() Enthusiast ![]() ![]() ![]() Joined Jul 8, '04 From Durham, NC Currently Offline Reputation: 6 (100%) ![]() |
Yeah I used silicone sealing stuff on mine as well. I think it's better than using a strong glue because it holds well and it could be removed pretty easily if you ever need to.
![]() Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) ![]() |
silicone for me too.
the clips are total rubbish and I can't believe toyota would use something so pathetic when they could easily be glued on in the factory. maybe they planned on selling loads on new rubbers/headlight units as spares after the originals failed? who knows. |
Enthusiast ![]() ![]() ![]() Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) ![]() |
![]() ![]() ![]() ![]() -------------------- ![]() Darin H. |
Lo-Fi Version | Time is now: February 17th, 2025 - 7:39 AM |
