> Removing the Intake Butterfly
post Jul 9, 2003 - 9:35 PM
Milds3vn
Joined Feb 11, '03
From Phila, PA
I saw this somewhere about removing the intake butterfly which i guess opens under increased throttle but closes at idle or something like this. Can you remove the intake butterfly on our cars if we even have one? Will it help etc. etc...
post Jul 9, 2003 - 9:44 PM
Inferno
Joined Jan 30, '03
From Virginia
Why would you need it to be open when you're not driving it? Also..it might help protect against water getting inside your engine.
post Jul 9, 2003 - 9:50 PM
blkGT
Joined Jun 10, '03
From FL
I've heard alot about this. But only with 7th generation celicas. My cousin has a car at www.teamcelica.com
Search their forums. I believe they've talked about it alot.
post Jul 10, 2003 - 9:19 PM
Milds3vn
Joined Feb 11, '03
From Phila, PA
Yea I dont know either thats why I asked, I thought maybe it makes it more responsive because those flaps dont have to open and your probably more likely to get water in the intake when your driving than just sitting still so I dont think thats why its there but then Im guessing.
post Jul 13, 2003 - 4:13 AM
Pvc99gT
Joined Sep 16, '02
From Somewhere around Chi-Town
the butterfly valve should fly open at full throttle or close to it. i dont think it would make much of a difference if you took it out, cuz when u slam it (wanting speed/power/acceleration) it flys open. but when your just normally driving i believe it is constantly opening/closing (so it looks like a butterfly's wings) but that is just what makes sense, i have never looked at my throttle body while just chillin. but if it was closed, then no air to the engine... so no combustion. i dont see how it would make much of a difference, i would buy a new throttle body( a bigger one) before i took out my butterfly valve. its there for a reason, not exactly sure why, but unless you are a hardcore racer it is prolly better to leave it in there. and the valve opens all the way in a split second, and the stock airbox pretty much prevents any water from getting into the intake.
after thinking a bit more, its prolly as good a mod as "better ground wires" but i could be wrong. just seems a bit ridiculous. wiggle.gif
This post has been edited by Pvc99gT: Jul 13, 2003 - 4:15 AM
Lo-Fi Version Time is now: November 25th, 2024 - 2:36 PM
