![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) ![]() |
i was told my car is leaking transaxle fluid...any ways to fix this? inexpensivly? also my head gaskets, i need new gaskets but i dont know how to get the heads to come off? any help at all?
you mean your valve cover gasket, not your head gasket, right?
valve cover is very easy. all you do is remove your spark plug wires and unscrew the 4 30m nuts that hold the cover down. if your leaking tranny fluid then chances are its from your axle seals. not a hard job at all, but then again it all depends on your skill level with cars. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:57 PM |
