> 7AFE engine code 71 (EGR fault)
post Jan 19, 2007 - 5:47 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
Anybody got any hints or things that you have done to correct it?
post Jan 19, 2007 - 8:41 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
71 = EGR (Exhaust Gas Recirculation) system malfunction.
EDIT: All I know about "71" is this...
This post has been edited by malpaso: Jan 19, 2007 - 9:27 AM
post Jan 20, 2007 - 3:40 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
fix/clean your EGR...
post Jan 20, 2007 - 3:59 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
however, if you've swapped a jdm 7afe/4afe - it will also read a 71 in engine codes.
but im sure this isnt your case.
post Jan 21, 2007 - 9:30 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
Removed the EGR tube from the old engine to clean it and install on the newer engine, swapped over the EGT probe and tested the VSV, swapped over the vacuum module and checked it's filter, I'll keep you posted as to what corrects this condition.
Why would a JDM 7afe trip the light? Got any links to this info?
post Jan 22, 2007 - 5:20 PM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
QUOTE(Blakout16 @ Jan 20, 2007 - 8:59 AM) [snapback]519459[/snapback]
Well well the plot thickens! Cleaned up my egr tube and valve and this afternoon, during the swap I discovered the difference between a JDM motor and a US motor! Viola! no port for EGT gases to flow thru.
So I do have a JDM 7AFE(bought off ebay for cheap) although not advertized as such. Maybe it's time for Paypal Protection to step in and refund some cash. I'm glad GA isn't too stingent on emission testing. I ended up leaving the current EGT tube and valve installed and moved the EGT probe up against the head for some all inportant heat to see if the MIL light will illuminate again. I'll post results. I'm thinking maybe tap into the heater hose for a heat source for the probe.
post Jan 27, 2007 - 2:16 AM
dans_st
Joined May 24, '03
From Andrews TX
is there anymore info on JDM 7afe's here, did search couldn't find much
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Jan 27, 2007 - 5:23 AM
6strngs
Joined May 12, '06
From Wilmington, NC
my 5sfe threw a code 71 a couple days ago. I had disconnected the vacuum hose between the EGR and it's vacuum source, then when I plugged it back in I had the CEL. I'm still trying to figure out what it is.
post Jan 29, 2007 - 8:08 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
QUOTE(6strngs @ Jan 27, 2007 - 10:23 AM) [snapback]521804[/snapback]
If the EG probe is not getting hot exhaust gas it will cause the CEL to come on. Clean the EGR, tube assy so it can get the hot gas needed.
Lo-Fi Version Time is now: November 28th, 2024 - 10:47 AM
