just got back from the dyno. i made some really good power from the ct26 with water injection. ended up hitting 247hp and 270tq at 16psi ! thats an 18hp and 21tq gain from where i was before !
video from the dyno] http://www.youtube.com/watch?v=rgSDcuXc2vY ![]() This post has been edited by lagos: Jan 28, 2007 - 4:22 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) ![]() |
nice. the water injection really helps alot. can we see a comparison from the graph before and this?
This post has been edited by shin: Jan 20, 2007 - 4:50 PM -------------------- |
here is the before and after. the dyno operator started to record my dyno a 4k of my WI run, but you can clearly see how it made a lot more power through the entire rpm range
![]() This post has been edited by lagos: Jan 20, 2007 - 5:01 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
270tq...whoa. Fanstastic results.
A/F looks real good too. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
QUOTE(jgreening @ Jan 20, 2007 - 5:06 PM) [snapback]519536[/snapback] 270tq...whoa. Fanstastic results. A/F looks real good too. for the 1st run, my a/f ratio was getting lean into the 13s (but with no knock). i had to add about 10% fuel with the safc to get it into a nice and safe 11s -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(lagos @ Jan 20, 2007 - 4:09 PM) [snapback]519537[/snapback] QUOTE(jgreening @ Jan 20, 2007 - 5:06 PM) [snapback]519536[/snapback] 270tq...whoa. Fanstastic results. A/F looks real good too. for the 1st run, my a/f ratio was getting lean into the 13s (but with no knock). i had to add about 10% fuel with the safc to get it into a nice and safe 11s Were the numbers higher on the first run? -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
very nice art! that WI is probably your best mod yet
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) ![]() |
oooooh man ive been waiting for this thread for a couple weeeks now
![]() Nice numbers Art, I think Manny hooked his WI up this afternoon. I wonder what 18 psi would have given you? |
GREAT results art, why'd you start your run so late?
now i can back up your raves about smurf piss as well! got my kit installed a little while ago...this stuff is GREAT. -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) ![]() |
My best run was 287hp and 290ft/lb .. at 14-15psi.. but for some reason the lines are alll over the chart.. they start to smoothen out after 6K... I need to figure this out..
After my first run guy told me I did 299hp.. turns out I guess that was on STD correction tho not SAE.. bleh. Also either my AEM wideband is reading out wrong or their wideband in my muffler was reading out wrong.. They had me at near 14afr.. yet the whole time I watched my gauge and I never broke above 11... except for when I hit 19PSI then I saw 11's... yet my best power seemed to be at 14-15psi.. so I gotta figure out what is going on.. I have a few idea's already. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
QUOTE(presure2 @ Jan 20, 2007 - 8:13 PM) [snapback]519570[/snapback] GREAT results art, why'd you start your run so late? now i can back up your raves about smurf piss as well! got my kit installed a little while ago...this stuff is GREAT. i started the runs at like 3k to match up with my old ones, but i think the dyno operator didnt start recording till 4k for some reason. he did the same thing on punishers car. steve, after looking at your dyno again, you do run out of fuel on your 1st 19psi run. then after you turned the boost down to 14psi, you have the fuel, but you have MAJOR knock response. the cause of it is either your timing or your turbo. everyone on here and mr2oc uses STD correction. so its ok to post your numbers in that. This post has been edited by lagos: Jan 20, 2007 - 8:28 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(Punisher @ Jan 20, 2007 - 8:18 PM) [snapback]519571[/snapback] My best run was 287hp and 290ft/lb .. at 14-15psi.. but for some reason the lines are alll over the chart.. they start to smoothen out after 6K... I need to figure this out.. After my first run guy told me I did 299hp.. turns out I guess that was on STD correction tho not SAE.. bleh. Also either my AEM wideband is reading out wrong or their wideband in my muffler was reading out wrong.. They had me at near 14afr.. yet the whole time I watched my gauge and I never broke above 11... except for when I hit 19PSI then I saw 11's... yet my best power seemed to be at 14-15psi.. so I gotta figure out what is going on.. I have a few idea's already. congrats on the great #s..post the charts i bet you get some nice response outta the 'spud too! be sure to post that on mr2oc too, they'd like to see those results as well. -------------------- Former Team 5SFTE pro member ;)
QUOTE(jgreening @ Jan 20, 2007 - 6:33 PM) [snapback]519549[/snapback] QUOTE(lagos @ Jan 20, 2007 - 4:09 PM) [snapback]519537[/snapback] QUOTE(jgreening @ Jan 20, 2007 - 5:06 PM) [snapback]519536[/snapback] 270tq...whoa. Fanstastic results. A/F looks real good too. for the 1st run, my a/f ratio was getting lean into the 13s (but with no knock). i had to add about 10% fuel with the safc to get it into a nice and safe 11s Were the numbers higher on the first run? 1st run made 248 and 271... so about 1hp difference. id rather loose that and be safer. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() I would've done better.. but something is up.. I don't know why the power is all over the damn place.. stick it up on mr2oc.. maybe they can lend some insight.. I'm gonna check some things out when I get the chance.. too tired to give a fruck right now. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
seems like your going lean, and hitting knock response from ~4800-6K+
are you running 550s? or the stockers? -------------------- Former Team 5SFTE pro member ;)
I don't feel like typing everything up here so u can read the whole run down with my engine on mr2oc
http://www.mr2oc.com/showthread.php?p=2363221#post2363221 it's the stockers.. if that is the case than my wideband is lying to me.. or the fuel ain't getting burnt in the cylinders... -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
![]() Enthusiast ![]() ![]() Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) ![]() |
very nice gains
![]() -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
Nice numbers guys. Looks like a great dyno day.
-------------------- ![]() I will return one day. |
video from that run added to 1st post
defgephs camera mount was used (sticking out the window) This post has been edited by lagos: Jan 20, 2007 - 11:43 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(presure2 @ Jan 20, 2007 - 7:52 PM) [snapback]519580[/snapback] seems like your going lean, and hitting knock response from ~4800-6K+ are you running 550s? or the stockers? classic knock response whether the a/f is correct or not. This post has been edited by jgreening: Jan 21, 2007 - 12:24 AM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:12 PM |
