> ECU readings from my 1/4 mile, just take a peak :)
post Jan 21, 2007 - 2:54 AM
well i took some logs using my laptop and a special program to learn a little more about what my car is doing and this is what i came up with so far
it displays the ET then the data after that the titles are at the top as to what it is
lambda = AFR but you can see a few interesting things going on
if you look you can see the gear change from 1st to 2nd.....run lasted ~14.3 seconds
Lo-Fi Version Time is now: February 22nd, 2025 - 7:53 AM
