> bent luck
post Jan 21, 2007 - 12:39 PM
phosai26
Joined Nov 28, '06
From Atlanta, ga
yea so today i bent the hell out of my A frame on my passenger side . anyone happen to have a spare one or know of where i can get one for a good price?
driver side (notice the spacing from wheel to fender)
passenger side (notice the offset)
This post has been edited by phosai26: Jan 21, 2007 - 2:10 PM
(Oo oO)
my angels
post Jan 21, 2007 - 1:25 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
WTB: larger pictures..
if the frame is bent...dont even bother. u wont beable to take off all the chasis and interior and what not...(you could but it would SO time consuming that its IMO totally pointless)
Kawi Love
post Jan 21, 2007 - 1:37 PM
azian_advanced
Joined Apr 18, '05
From Calgary
by A frame, is that the lower control arm (in an A shape)? if so, it's isn't that hard to replace.. well, ok, it'll take about a couple of hours of labor.
post Jan 21, 2007 - 2:09 PM
phosai26
Joined Nov 28, '06
From Atlanta, ga
Yes it is the lower control arm, thats the part that i actually need
(Oo oO)
my angels
post Jan 21, 2007 - 2:20 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
what did you hit? a curb?
post Jan 21, 2007 - 2:46 PM
phosai26
Joined Nov 28, '06
From Atlanta, ga
QUOTE(purplegt4 @ Jan 21, 2007 - 7:20 PM) [snapback]519747[/snapback]
surprisingly yes
(Oo oO)
my angels
post Jan 21, 2007 - 9:51 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i did the same with my 5th gen one time.. and it was the passenger side too.. lol
post Jan 23, 2007 - 5:42 PM
been there, done that...lol
they list @ toyota for ~200$ ea.
youll wanna replace the ball joint while your there.
post Jan 24, 2007 - 12:03 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
:woot: i bent mine too!
you can get the balljoint and arm together assembled on ebay for cheap or you can grab the parts at an autoparts store. heres a tip tho, the autozone balljoint needs some assembly and the nuts they use stripped on me at 1/2 the torque spec! i reused the old nuts without problem.
phosai26
Joined Nov 28, '06
From Atlanta, ga
QUOTE(presure2 @ Jan 23, 2007 - 10:42 PM) [snapback]520537[/snapback]
how much did the ball joint cast you?
(Oo oO)
my angels
post Jan 24, 2007 - 12:12 AM
phosai26
Joined Nov 28, '06
From Atlanta, ga
Should i replace both lower arms since im putting a new one in the passenger side or will the ride be fine if i just replace the bent one?
(Oo oO)
my angels
post Jan 24, 2007 - 2:09 AM
azian_advanced
Joined Apr 18, '05
From Calgary
no need to replace the other one unless it was also damaged.
post Jan 27, 2007 - 9:32 AM
the ball joint is ~40$
the other side will be fine without replacing it, ive been driving around like that for a few years.
post Apr 2, 2007 - 10:10 PM
purplegt4
Joined Feb 7, '03
dan says: control arm is easy to replace.
hanes manual says you have to remove most of the suspension to replace the control arm.
anybody?
afterwards get an alignment, correct?
post Apr 2, 2007 - 10:15 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
19mm or 3/4 deep socket with a ton of air and pb blaster...take the nut off slide the pin down near the fuel tank, do for both sides, get new arm same size as old one, mark with white out, put new arm on, slide pin down and nut it. takes 20 minutes if you have an air compressor.
i have a brand new passenger side control arm #2 for $110 shipped
This post has been edited by LewFX: Apr 2, 2007 - 10:16 PM
post Apr 2, 2007 - 10:43 PM
purplegt4
Joined Feb 7, '03
near fuel tank? well i just need to replace my front-driver side control arm.
btw no thanks on the arm. i already have my part.
yea it said i need to take the axle nut off...etc. etc. i'm thinking i should just take it to the shop and have an alignment done at the same time.
post Apr 2, 2007 - 10:50 PM
yea word i got a spare passenger side if u needz (to original poster)
50$
This post has been edited by playr158: Apr 2, 2007 - 10:54 PM
Lo-Fi Version Time is now: November 29th, 2024 - 4:32 AM
