> car alarm, it doesnt arm
post Jan 21, 2007 - 9:46 PM
chandy1986
Joined Mar 23, '06
From Mass
I have no idea how it works and i didnt get it installed. That previous owner did that. I can open and lock my doors with the remote but the alarm doesnt engage. I tested it by starting my car after arming it but the car started and alarm didnt go off. I even banged my car a few times to set it off.
Does my car alarm need to get its batteries changed biggrin.gif ?
Thanks for any advice
post Jan 21, 2007 - 9:50 PM
Hanyo
Joined Aug 16, '03
From Bay area
most of the time. start kill is an optional item. You may need to get a start kill relay installed.
post Jan 21, 2007 - 9:57 PM
chandy1986
Joined Mar 23, '06
From Mass
If start kill is when u try to start the car and it does than I think i have that.
so u think i need to change the batteries, thats shouldnt be hard to do. What else could be wrong even after changing it?
post Jan 22, 2007 - 10:25 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Changing the batteries won't help you - if it is unlocking and locking the doors then the battery is fine. The battery of your car gives the alarm it's power not the batteries in the remote. Perhaps you just have keyless entry and not an actual alarm? Take a picture of your remote and I'll see if I can help you.
This post has been edited by Negative: Jan 22, 2007 - 10:25 AM
post Jan 22, 2007 - 2:23 PM
chandy1986
Joined Mar 23, '06
From Mass
I'm pretty sure i have an alarm too biggrin.gif it just stop working but keyless entry still works
IPB Image IPB Image
Theres a module i found under the dash that says 660XP so i think its a python 660xp alarm
hope any of that can help
post Jan 24, 2007 - 7:49 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
chandy
Try opening a door and pressing arm - disarm - arm.
That is the pattern to enter and exit valet mode with a DEI alarm. DEI makes Python's. The led on the dash should go from on solid to off and then it should flash when you close the door and arm the alarm.
Hope this helps.
Lo-Fi Version Time is now: February 22nd, 2025 - 12:59 AM
