> My alarm is toast, possibly a fuse?
post Jan 22, 2007 - 1:16 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Well a while back I posted saying that I had all my doors open (including hatch) and I accidently hit the button on my alarm thing and it locked the doors, except this time the blinking LED in my dash to show it is armed was a solid red light. and has been ever since. It still would lock the doors and all, so I saw no reason to worry, except now I have found that my alarm does not work at all. I opened the hatch and got something out of it, closed it, and then went to get in and my door was locked. All this time I though my alarm still worked, but now it is only keyless entry. I think a fuse might have blown, but I don't know where that fuse would be, because it was all installed by the previous owner.
Maybe a fuse? or do I need a new alarm?
This post has been edited by 95CelicaST: Jan 22, 2007 - 1:17 PM
**** Photobucket
post Jan 23, 2007 - 4:37 AM
If your keyless entry still works then I wouldn't think that it's a fuse. I'd find the alarm and check the wiring.
post Jan 23, 2007 - 5:35 AM
creis
Joined Jan 10, '04
From Shoreline, WA
sounds like all it needs is a reset, just pull the connecter off for a bit, or if it has a reset jumper inside you can do it that way. (some have em, its just a standard circut board jumper. swap it over and it resets)
doubt its a fuse if it still works to unlock the doors, werid that setting it with the doors open did anything, my celicas just chirped at me and showed an open door (was a 2 way pager) did not set the alarm if something was open.
post Jan 23, 2007 - 7:45 AM
chandy1986
Joined Mar 23, '06
From Mass
i've got the same problem with my car. when ever i lock the doors it would chirp once and three times when i unlocked the doors. now nothing happens except for the blinking of the lights. i'll try and see if i can reset the thing when my car comes back from the shop
this may just solve my problem biggrin.gif TY
This post has been edited by chandy1986: Jan 23, 2007 - 10:21 AM
post Jan 23, 2007 - 10:16 AM
95CelicaST
Joined Feb 5, '05
Well I'm not quite sure where the brains of the alarm is, actually. I suppose I will get up under the dash on Wednesday and see what I can find. It wouldn't be in the engine compartment would it?
**** Photobucket
post Jan 23, 2007 - 10:21 AM
Negative
Joined Apr 28, '04
From Houston, Texas
No if it's factory it's almost directly above the acc pedal. [usually LOL]
post Jan 23, 2007 - 10:22 AM
chandy1986
Joined Mar 23, '06
From Mass
Mine is placed under the dash near the fuses. so the first place to look is near the fuses i'm guessing
post Jan 24, 2007 - 7:51 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
95celicast it's sounds like you may be in valet mode.
try the same thing I recomended to chandy1986. open a door and press arm disarm arm. If the light goes from solid red to off the alarm was in valet and now it's not. should work fine.
post Jan 24, 2007 - 11:00 AM
95CelicaST
Joined Feb 5, '05
Still solid red light. Still no alarm.
**** Photobucket
post Jan 25, 2007 - 11:19 AM
AudioFreak
Joined Dec 19, '02
QUOTE(95CelicaST @ Jan 24, 2007 - 11:00 AM) [snapback]520799[/snapback]
Solid red is valet mode. Do you know if there is a valet switch somewhere in the car? Also you can try pulling the battery for a while and see if the brain will reset. Hopefully you don't have a battery backup.
post Jan 25, 2007 - 12:22 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
put the key in turn it to ON then off then ON again then off then ON then off then ON and press the switch. biggrin.gif
post Jan 25, 2007 - 12:54 PM
95CelicaST
Joined Feb 5, '05
Unplugging the battery does nothing. I had the battery out last weekend and it is still solid red.
I will try that here in a second.
**** Photobucket
post Jan 26, 2007 - 11:09 AM
95CelicaST
Joined Feb 5, '05
I did however finally hook up my ST202 fog lights... pretty...
**** Photobucket
Lo-Fi Version Time is now: February 23rd, 2025 - 7:02 AM
