> loud fast rattle sound passen wheel when let off gas
post Jan 24, 2007 - 12:36 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
about 3 wks ago installed cross drilled slotted rotors and ceramic pads, was fine at first, week later it started making a horrbile screaching noise, had it checked out the brake clips were old and hitting the rotor and grinded away, so orderd new clips, once again no problems for a week. but now when i let ofthe gas it sounds like my rotor is not tight? and hitting the caliper bracket who knows,...anywy its annoying as hell.
well i jsut read the bent luck thread and i did hit a deer last year, guess i need to check to see if my a frame and ball joint are toasted.
any one have any suggestions i'm pretty sure when i was working on the caliper i tightened the 15mm bolts that atttach the caliper bracket to the rotor pretty good, could i have not tightened it enuff
this problem comes and goes
any sugestions would be apprecaited
This post has been edited by illneversellmycelli: Jan 24, 2007 - 12:36 PM
post Jan 24, 2007 - 3:41 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
try the bearing, make sure its rotating straight
post Jan 25, 2007 - 11:19 AM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
anyone second lewfx's motion? I probally go by the shop and have them check the bearing
post Jan 25, 2007 - 11:36 AM
LewFX
Joined Jan 28, '05
did you resurface the rotors since the clips were touching them?
post Jan 25, 2007 - 4:07 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
yes that rotor had to get spun like 3 times or so
QUOTE(LewFX @ Jan 25, 2007 - 11:36 AM) [snapback]521187[/snapback]
Lo-Fi Version Time is now: December 3rd, 2024 - 5:45 AM
