Modifying projectors, how do you reseal them |
Jan 24, 2007 - 1:07 PM |
Enthusiast Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
I just took the projectors off the car last night and want to modify them for lhd use, but want to know how to reseal them after you boil them.
IIRC you use the same glue that is already on there, but if you do, then how would you reheat that glue up after you open them. |
Jan 24, 2007 - 2:45 PM |
Enthusiast Joined Nov 29, '06 From South Florida Currently Offline Reputation: 0 (0%) |
question: why would you boil the projectors? and clear silicone adhesive should be good enough to reseal them, just make sure its got silicone all voer so moisture doesnt enter
Jan 24, 2007 - 2:48 PM |
i bake my headlights but
you can reuse the glue thats in there just bake it at 200* for a few seconds until it gets tacky then push the glass in, reheat push the glass in and hold, and do it one more time to make sure its good or clean out all the old crap with a knife, go and get some clear silicon adhesive, lay a small bead all the way around in the groove, press the glass in and let cure for recommended time |
Lo-Fi Version | Time is now: January 12th, 2025 - 6:43 AM |
