> i'm getting more power? but i didn't do anything?
post Jan 25, 2007 - 2:24 AM
azian_advanced
Joined Apr 18, '05
From Calgary
need some clarification:
to start off, i bought my car with 97,000 kms on it, and the engine was pulling alright w/o problems what so ever.. but now, i notice the more i drive it the stronger it becomes... i got the car nov 2005 and last summer of 2006 i noticed that it felt a little stronger than when i first got it. and recently, last sunday, i was on the hwy going 160 kms/hr (a little over 100 miles/hr) and it was probably my 3rd time ever going over 3500 rpms but never passed 4k. and at that speed i was actually nearing redline, then i reduced speed again.. did that about 2 to 3 times (i was not racing btw! i don't race. just to get the point out. i'd say it was more like a 'spirited run').
later i stopped at a coffee stop for donuts for a little while. when i got back to drive the car again, it seemed like i was getting more power for some reason. it was like i was getting another 10HP or so i think. the car would pull stronger and the rpm would rise quicker. it's been like that since last sunday. i dunno, but did that 'spirited-run' have anything to do with my engine getting more power? my car is now at 109,000 kms on the odometer. since the time i bought the car, i think there has been an increase of about ~15-20HP.
btw, nothing was changed in the engine or drivetrain. and i have no engine or performance mods at all (just suspension), so everything else is still stock. i've only resetted the ECU and performed regular oil changes . can anybody explain what's going on?
post Jan 25, 2007 - 2:29 AM
phonex98
Joined Mar 25, '06
yea.... the transition from warmer spring air to colder winter air ? Atleast that's what has done it for me on the chilly west coast.
----- '94 ST hatch --- Yellow -----
post Jan 25, 2007 - 2:36 AM
quicknstyle
Joined Oct 3, '02
From HOUSTON
false sense of the imagination??? i dunno, temperature changes for colder air??? but more than likely all in your head man...
post Jan 25, 2007 - 11:40 AM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
We can take each other's car for a spin and then you'll know if the 15-20 HP is all in your head or not. wink.gif
When did you reset the ECU?
post Jan 25, 2007 - 12:10 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
This post has been edited by purplegt4: Jan 25, 2007 - 12:11 PM
post Jan 25, 2007 - 12:23 PM
nate95
Joined May 5, '05
From mattoon, IL
laugh.gif laugh.gif ... maybe when you bought the car it hadn't been taking in good care, and when u got it somehow u just restored some of the power that it had lost. maybe driving it that fast woke the beast up biggrin.gif
post Jan 25, 2007 - 12:32 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
QUOTE(nate95 @ Jan 25, 2007 - 12:23 PM) [snapback]521209[/snapback]
Well there has been talks about an engine loosing its power if you run it in low rpms all of the time. Carbon builds up in your engine if you don't rev it high enough alot. So when you took it out on that "spirited run" you could have burned enough of that carbon off to gain some extra ponies... thats what a volkswagon owner told me once.
Darin H.
post Jan 25, 2007 - 12:47 PM
Kadett
Joined Mar 17, '05
From The Netherlands
I did feel a difference driving around during a very hot Autum (September/october) day and the same night when difference in temperatures was about 20 degrees.
This was with the 3S-GE.
@azian: You dont drive past 4k rpms??
I barely keep it under 4k rpm when driving biggrin.gif only for the first 15minutes/15 kilometers to get the oil/water temperature at the right numbers.
post Jan 25, 2007 - 5:21 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(Starcraftjunkie @ Jan 25, 2007 - 10:40 AM) [snapback]521190[/snapback]
during the summer at the same time when i did an oil change and switched from premium 91 octane gas to regular 87 gas.. i wanted to reset the ecu so that it'll tune itself to efficiently run on 87 octane.
and i might have overexaggerated, i'd say it was probably like 8-14HP
i figured the ecu would program itself according to the driver's driving habits.. and i agree that carbon build up will naturally occur when driving constantly on low rpms.. perhaps i should occasionally start giving my engine more excercise on the hwy.
QUOTE(Kadett @ Jan 25, 2007 - 11:47 AM) [snapback]521219[/snapback]
i can also feel the difference in power depending on different temperatures.. being in the center of the continent, during the summer i was able to feel the difference between our cold nights and hot days. it was as if the car was lagging in the day and then suddenly become a bit stronger in the evening.
oh and in this city, there are very few freeways (most of which are not my common routes) and most of the roads are not as wide and long as in bigger cities. and there are traffic lights and stop signs on nearly every corner (well sort of), so i'm usually driving an average of 60 kms/hr (~37miles/hr) and sometimes on 5th gear during very slippery conditions.. man, it sucks cuz the winters here keep me from driving at high rpms.
post Jan 25, 2007 - 5:23 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(Kadett @ Jan 25, 2007 - 5:47 PM) [snapback]521219[/snapback]
Yea the 3SGE seems to be particularly sensitive to outside air temperature.
post Jan 25, 2007 - 5:41 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
some people say that with the build up of carbon in the combustion chamber it raises the compression alil...idk how much carbon you would have to build up to feel a change it power, but the build of carbon...idk bout that. Sounds bad imo
Now SR powered
post Jan 25, 2007 - 9:20 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
who knows but maybe t since you got your gt-four front on there its trying to act like a true gt-four......... prolly not but its funny
air temps and other conditions are probably why its feeling like it is
-Brian
post Jan 25, 2007 - 10:47 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
higher chamber temps may have un-fouled plugs.
post Jan 26, 2007 - 9:49 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I suposed Toyota expert told me that the Toyota and GM blocks seem to get better with age and produce more hp. I talked to him for awhile, and he made me feel like I didn't know anything, so I trust what this guy says. Although, the oppisit is true for the heads on at least the 5sfe motors, I found that out. They wear a good bit, and not in a good way.
Live Free, Be Happy
post Jan 26, 2007 - 9:58 AM
Mynzeyes
From Franklin/Nashville, TN
...really?
am i really reading this?
and people are incouraging this?
AIM==Mynzeyes
post Jan 26, 2007 - 1:46 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Mynzeyes @ Jan 26, 2007 - 9:58 AM) [snapback]521530[/snapback]
...really?
Do you have a better idea? The guy said he got more power, everyone knows that's just about impossible. But, why not entertain ideas as to how it could be possible? Therefore, answering his question instead of just bashing on him.
Live Free, Be Happy
post Jan 26, 2007 - 2:18 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(Bigmeanbulldog55 @ Jan 26, 2007 - 6:49 AM) [snapback]521527[/snapback]
There is no way for extra wear and carbon build up in a motor can create more HP.
The only reason Gm blocks give better performance with age is because they where built with very loose tolerences. Meaning when they are new, they had alot of internal friction between parts. So as they age, they moving parts polish and smooth each other out. There for reducing friction and increasing Hp.
With our new motors, engine tolerence are very close to perfect.
Even with extra carbon build up in the engine, the extra carbon adds weight to the piston and valves making more rotational mass in the engine itself, this alone will offset the power gains from compression increase. If such little compression was helpfull you can get the same HP gain just by using longer spark plugs.
Back on topic:
Clearing out the carbon from the engine and catilatic converter is probably the main cause of performance increase. Also cooler air temperatures is a major contributor of sudden performance increase.
This post has been edited by Hanyo: Jan 26, 2007 - 2:25 PM
Lo-Fi Version Time is now: December 1st, 2024 - 1:49 AM
