![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) ![]() |
Does anybody experiences this? When going over rough roads, like on dirt or un even pavement, theres a clunking coming from the steering wheel, it seems to comes from somewhere under the gauge cluster. Almost like a plastic-ish sound. it really goes like cluk cluk cluk!!! ..its kinda bothersome
![]() Also, if I turn the wheel left and right its like I can reprodue the sound just lower,,I dunno how to explain,, -------------------- ![]() -Rémy 02 SiR, 08 250R |
![]() Enthusiast ![]() Joined Dec 18, '06 From Bristol, UK Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Rayme @ Jan 25, 2007 - 9:41 PM) [snapback]521312[/snapback] Does anybody experiences this? When going over rough roads, like on dirt or un even pavement, theres a clunking coming from the steering wheel, it seems to comes from somewhere under the gauge cluster. Almost like a plastic-ish sound. it really goes like cluk cluk cluk!!! ..its kinda bothersome ![]() Also, if I turn the wheel left and right its like I can reprodue the sound just lower,,I dunno how to explain,, yeap i think i know the one... if its the same rattle as ive got its incredibly annoying! If you press down on your steering coloum shroud does it go away???? ive got a pen wedged in there at the moment - ive had it all apart to try and find the rattle but i cant find it anywhere! -------------------- ![]() |
lol! I'll try that...
![]() Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) ![]() |
I think I know the problem u guys have, the steering coloum is attached to the body with for bolts, just tighten them and all will be good, I had that problem but I figured it out.
The only thing you have to remove is the plastic where there is the bonnet lever to see under the coloum ![]() -------------------- ![]() |
This might be the case I'll check that out! thx!
I can'T seem to find those bolt..I took everything apart and nothing was loose there!
So the 4 nuts are tightened not loose, I u have pic so I can see what yr looking at exactly i can help more
I took the bottom panel of, and there's another panel under it, I re tighten all the bolt but nothing loose enough to make my steering vibrate.
I looked at where the steering enters the firewall and it enters a big rubber tube..nothing I can touch there. I also removed the shroud around the column (where the blinker/wiper levers are) and everything seems tight. I even checked the steering rack..looks solid, thsi is driving me nuts!!!!! -------------------- ![]() -Rémy 02 SiR, 08 250R |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
I don't have as severe as a problem as you guys but there is a rattle that goes away when I put pressure on my steering wheel. However, it's only because of my incredibly stiff motor mounts otherwise there would be no noise. I'll have to take a look and see if I can tighten those bolts just a bit.
-------------------- ![]() Project ST204.5 99.88946% complete... |
I'm starting to think it might be the u-joints that are a little worn, and I bet toyota don't give them for free
Guys you can Also try and thighten Up the Subframe, if it is only doing it on rough roads there could be a chance of that or it could be simply a ball joint
![]() I had 2 bolts that where slightly loose on the subframe and it too me ages to figure out where the noise was coming from. There are 2 bolt that connect the subframe to the hub the bolt on connected to the subframe was slightly loose as it takes alot to tighten, the trick is dont jack the car look for that are witch is mounted on a bush and lay on the floor and reach to tighten it on both wheels. Then jack the car and tighten up the rest of the Sub frame to be sure. All you need is a 19mm spanner or ratchet and socket ![]() Tell me how it goes ... -------------------- ![]() |
Lo-Fi Version | Time is now: February 18th, 2025 - 3:21 PM |
