Jan 29, 2007 - 12:03 PM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '06 From New Jersey Currently Offline Reputation: 0 (0%) |
I replaced it with a 7.5 (which is what the orginal fuse was) I turned the lights on and off a couple of times and the fuse didn't blow. used a fuse checker to make sure, but if the fuse was going to blow it would of done it right then correct? -cnelson.
-------------------- "Drive Well...
...Drift Better" |
Jan 29, 2007 - 12:07 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
QUOTE(cnelson @ Jan 29, 2007 - 9:03 AM) [snapback]522273[/snapback] I replaced it with a 7.5 (which is what the orginal fuse was) I turned the lights on and off a couple of times and the fuse didn't blow. used a fuse checker to make sure, but if the fuse was going to blow it would of done it right then correct? -cnelson. Not necessarily. I had mine wired up and I drove around with them on for a bit. I armed and disarmed my non-working alarm (when I arm and disarm my fogs blink once or twice) and it all looked okay. It wasn't until the next day that the fuse decided to go. I think you should be alright. Give it a day or two. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
| Lo-Fi Version | Time is now: September 5th, 2026 - 11:35 AM |
