> is there a way to convert my drum brakes to disk brakes
post Jan 27, 2007 - 2:54 PM
rspjean
Joined Aug 20, '06
From Kissimmee
post Jan 27, 2007 - 3:09 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(rspjean @ Jan 27, 2007 - 11:54 AM) [snapback]521848[/snapback]
yes sir there there is. I did it on mine, and it have a 94 st coupe too. I just took the rear brakes off of a 97 celica GT. But really it doesnt matter which year 94-99. You will need the whole assembly including disks, calipers backing plates and hand brake cables.
To make the job easier i went to a junk yard and removed the whole hub assebly via two large bolts that attact it to the suspension. your drum brake assembly is attactched the same way with those two bolts. So just take those off and remove all the lines, then reatach the new disk brake assebly and attatch brake and hand brake lines. May not make sense untill your under your car... but there is also a write up in the how to section. good luck! http://www.6gc.net/howto/convert_rear_drums_to_discs
Lo-Fi Version Time is now: February 21st, 2025 - 5:15 PM
