> Help with crank sensor, gotta get this 5sgte running
post Jan 29, 2007 - 1:37 AM
ice23q
Joined Jan 16, '04
From sydney australia
Guys i need help before i burn this 5sgte to the ground. Its driving me crazy.
I need to know if there is a kit for a crank angle sensor on a 3sgte.
I have seen them on the net but stupid me did not save the site.... After many hours over the weekend and a smashed mouse aganst the wall i failed to find a kit.... Am i looking in the wrong place or do they just not want me to find it.
The cam and crank sensor in the factory dizzy is not working or faulty so im realy wanting to go with something aftermarket.....
[b]HELP WOULD BE GREAT.........and i hate catching the train to work every day.
312whp with more to come....
post Jan 29, 2007 - 7:27 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
The 3sgte gets its crank or cam angle position from the distributor. I have one laying around. What problems are you having with the car? If you want the distributor let me know. later
post Jan 29, 2007 - 8:24 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
what standalone are you using? you could jbweld a magnet at TDC and use a halleffect sensor :dunno:
post Jan 30, 2007 - 12:25 AM
ice23q
Joined Jan 16, '04
i think that the wires from the dizzy for the crank and cam sensors are plugged in the wrong pins...
I cant find any info to say what wires are what...
Im using an Altronic SM4 standalone with an Altronic CDI 500R and quad coils....
Any info from you guys would be great.
post Jan 30, 2007 - 12:30 AM
Bitter
Joined Mar 11, '06
i know nothing about that standalone.
most that ive seen however can accept inputs from other sensors than stock ones. if you wanted you could setup a crank positon sensor...it'd be hard to get it as accurate as the one the car comes with tho, the one in the distributor unit.
post Jan 30, 2007 - 2:34 PM
ice23q
Joined Jan 16, '04
No No No.... what i need to know is what colours are what from the dizzy...
red=
green=
white=
black=
I should have explained it better before....
post Jan 30, 2007 - 2:54 PM
Alan
Joined Jan 23, '05
From Malta
QUOTE(ice23q @ Jan 30, 2007 - 2:34 PM) [snapback]522679[/snapback]
red=
green=
white=
black=
Dizzy ?
As in Distributer ?
post Jan 30, 2007 - 5:47 PM
Bitter
Joined Mar 11, '06
oh you just want the pinout for the distributor so you can doublecheck your wiriging? check the online BGB's on celicatech.
post Jan 30, 2007 - 11:48 PM
yungazzdriver
Joined Feb 15, '05
From Frederick, Maryland
hey electromotive sells the kit for the 3sgte and im going to use this aswell, seen it in action, and ........sexyness!!! but the part number for electromotive is 200 73003 goes for around 150$$ for mounting kit, mag sensor and spacer and trigger wheel
post Jan 31, 2007 - 5:50 PM
ice23q
Joined Jan 16, '04
got it working lastnight..... 13 pin combos later..... and it starts..
Thanks for your help guys......
Rik
Lo-Fi Version Time is now: February 22nd, 2025 - 10:54 PM
