21 Pages V  « < 7 8 9 10 11 > »
> My Engine Bay Renovation Thread, AE111 ECU conversion, wire tuck, and more...
post Mar 21, 2007 - 2:38 PM
QUOTE(playr158 @ Mar 21, 2007 - 10:31 AM) [snapback]538385[/snapback]
ok, i need to eventually do what your doing and don't really understand frown.gif
Which part don't you understand? I'll try to clear it up as best as I can. smile.gif
post Mar 21, 2007 - 2:43 PM
oh lol sorry my wording should have been better..
i don't understand the painting process as a whole...
This post has been edited by playr158: Mar 21, 2007 - 2:43 PM
post Mar 21, 2007 - 2:55 PM
QUOTE(playr158 @ Mar 21, 2007 - 12:43 PM) [snapback]538404[/snapback]
It's really not too bad...wash, degrease, sand (and sand, and sand, then sand some more), degrease, prime (can be optional), sand, degrease, then paint. Then you can wetsand and buff. Also, I did bodywork (filling dings and stuff) after I wetsanded everything, because you don't want body filler getting wet.
This thread details my painting process, and I learned a lot just reading online, especially at Autobody 101.
post Mar 21, 2007 - 3:41 PM
TaKtikal_6G
Joined Jun 23, '06
From Michigan
post Mar 23, 2007 - 1:53 AM
Today I installed the brake booster and master cylinders, and installed most of my brake lines.
There's how the new setup looks...much better than before in my opinion. smile.gif
On the crossmember, you can see where I mounted the proportioning valve and T-fitting.
The tools I used for cutting, flaring, and bending brake lines.
Here's a helpful tip if you're ever bending your own brake lines. Find some wire, and then you can cut and bend it into place before working with the actual tubing. This saved me a lot of time.
I'm about to pass out, so if parts of this don't make sense, that's why. wink.gif
post Mar 23, 2007 - 1:59 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Thats coming along very well. I wish I could do this with my car.
I will return one day.
post Mar 23, 2007 - 10:34 AM
DSToyo
Joined Dec 16, '06
From Maryland
thats looking AWESOME coomer, its coming along very nicely
you are very talented...where did you learn how to do all of this, it seems there is nothing you cant do, automotive wise.
post Mar 23, 2007 - 10:38 AM
awesome job coomer. your going to have a show ready car when its all done.
post Mar 25, 2007 - 5:37 AM
Today was a really good day...I worked on the site for about six hours this morning and then went home and got a fair amount done on the car.
I got the final brake line, the passenger side front one, done. I had it looking better than this one, and then realized that I'd forgotten to put the fitting on, so I had to throw that piece out. frown.gif I think this one looks decent though.
I also installed my Russell stainless brake lines on all four corners. They seem to fit pretty well and they look nice. They should give me a better pedal feel once the car is on the road. smile.gif
Once all the brake lines were hooked up and tightened, I put some fluid in the master cylinder and proceeded to get fluid flowing through the lines to make sure I don't have any leaks anywhere. I had a tiny leak right at the master cylinder, but tightening the fitting another third of a turn solved that. I'll bleed the brakes when someone is actually home to help me and then I'll check for leaks again.
I also finished up my steering setup. What I did was cut the two stock hard lines, then I attached reinforced vinyl tubing to them, which go to a T-fitting. The small part of the T-fitting then goes to a small clutch fluid reservoir that I found sitting at the junkyard...I don't even know what kind of car it came from.
Why go with a setup like this you may ask? Well, I no longer will have power steering, so this solution should make steering much easier than it was before with no power steering (when I just had the belt off.) ATF cannot compress (at least not very much), so with the power steering pump not spinning on the old setup, the system is full of fluid, but it cannot flow very easily at all, because the fluid must spin the pump.
With this setup, there is no pump in the way, so the fluid will flow through just fine. There will be a minimal amount of ATF in the system, and the reservoir isn't for holding fluid, but to allow air in the system to compress and escape if necessary, as the reservoir is not airtight. A lot of the Honda guys run setups similar to this and say it helps a ton compared to just removing the belt that spins the power steering pump. I can't wait to drive the car and see how everything feels.
post Mar 25, 2007 - 8:27 AM
amazing work chris.
major props.
how many hrs you figure you got into that bay???
hit your local autozone or whatever and pick up a "mightyvac"
it will make all your bleeding (clutch, brakes..) a one man job.
cant wait to hear your thoughts on those AGX's!!
post Mar 25, 2007 - 10:00 AM
Valo666
Joined May 15, '05
From Toronto
looking good coom. The engine bay is gonna look rediculus when its all finished. Also, thouse Russel brake lines are awsome. Ive been runnin em on my car for 6 months now and i love em.
BTW: the mario mushroom wrist band/brake resevoir cover = awsome..lol
post Mar 25, 2007 - 10:48 AM
94celicadude
Joined Mar 28, '04
From St.Louis
every time i check this thread, i get blown away twice as much as the previous one. This is truly amazing work, i wish i just had the time to do this to my car. This is one celica that i will travel thousands of miles to see in person one day. Great work, keep it up and keep us posted as usual. And also, i think i caught a glimpse of an adjustable shock residing within you shock towers. thumbsup.gif thumbsup.gif
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post Mar 25, 2007 - 10:52 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
coomer for featured ride! your car is So clean. i love it!
post Mar 25, 2007 - 12:32 PM
Culpable04
Joined Apr 17, '06
From New Jersey
you know we want details on how you got them to work on the celi.
how stiff are we setting the up ?
post Mar 25, 2007 - 1:07 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
first the mega body work thread now the engine bay renovation thread, you are a madman coomer, truly an inspiration.
i still remember reading all the painful threads about your swap, cops hassling you, and the for sale threads, the break in, its awesome to see you and your celi still together and you putting us all to shame with your ambition. make us all look lazy!
post Mar 25, 2007 - 1:35 PM
Thanks for the comments guys...makes me want to go home and work on it some more. biggrin.gif
As far as how I got the AGXs to work, it required a fair amount of fabrication. I've got a how-to prepared and will put it online once I get my car back on the road and ensure that the AGXs actually work.
I just ordered my fuel filter from EverythingG20 (I'm going to be using an OEM G20 fuel filter). I'm going to attempt to order a 100-amp, switchable, panel-mount Bussman circuit breaker here in town, since I can't find one online anywhere.
I'm also preparing my order from Summit for some parts. I'm getting remote battery terminals, parts to make my own stainless steel braided clutch line, and maybe some fuel line stuff...I'd like to run a stainless braided fuel line from the intake manifold to the fuel filter. I've just got a couple questions.
1. Does anyone know the size of the bolt hole on the the 4A-GE's intake manifold where the bolt that holds the banjo fitting and line is? I'm guessing 12mm x 1.25, but I'm not sure.
2. Does anyone know if anyone sells stainless braided fuel lines that have an open sort of end on one end so that I can clamp that end to my fuel filter?
post Mar 25, 2007 - 4:49 PM
laff09
Joined Jul 28, '06
From Delaware
Simply amazing. and I second itchy's demand for the yelli celi as featured ride!
post Mar 25, 2007 - 4:57 PM
Valo666
Joined May 15, '05
From Toronto
QUOTE(Coomer @ Mar 25, 2007 - 1:35 PM) [snapback]539653[/snapback]
1. check with club4age. there should b some one on the site that should know.
2. I would say see if russel has somethin. I think that they have open ends at the end that you could put a barbed filter on, or have a fitting that you could attach to a barbed fitting like on the fuel filter.
post Mar 25, 2007 - 5:04 PM
97lestyousay
Joined Jul 7, '03
QUOTE(Valo666 @ Mar 25, 2007 - 2:57 PM) [snapback]539688[/snapback]
Looking good Coomer, I am amazed at the progress.
The 4age forums have been down for a while. I can pull mine and measure
it if you need me to I don't know if the 16v is the same though.
JDM guy made me do it.
post Mar 25, 2007 - 5:05 PM
I just had a great idea as I was preparing to order my stuff for my clutch line. biggrin.gif
I think I'm going to run a hard line from the slave cylinder down the front of the transmission and under it, to a small stainless line, and then to a hard line which goes to the master cylinder. It's a longer path, but I don't see any real disadvantages to it.
That, or I'm thinking of just running a blingin' stainless line all the way from the slave cylinder to the lower firewall, where it'll meet with a hard line and then the master cylinder.
I can't decide between having nothing running over the tranny, or a very nice looking stainless line with anodized fittings. Decisions, decisions... smile.gif
I also cannot decide where I want to put the fuel filter. It needs to be reasonably accessible, but I don't want it to be too visible. I'm thinking lower firewall, or on the driver's side frame rail under the brake master cylinder. Anyone have any other suggestions?
Edit: Valo,
I did find a fitting that would work. Russell part number, 663010, which is $5.95 from Summit Racing. It's a -6AN male fitting on one end with a 1/4" tube on the other for attaching a 3/8" hose to. So I could have the stainless line, then that fitting, then a small fuel line hose, then my fuel filter.
Randy,
That's alright...you don't need to measure for me...I'll just check next time I go home...I need to measure some things before I order anything anyway. smile.gif
This post has been edited by Coomer: Mar 25, 2007 - 5:09 PM
Lo-Fi Version Time is now: February 17th, 2025 - 1:10 PM
