General Tune Up, What should i covetr |
Jan 29, 2007 - 11:49 PM |
Enthusiast Joined Sep 1, '06 From Michigan Currently Offline Reputation: 0 (0%) |
I'd like to do an all around tune up to my car, get it prepared for my various projects in the spring, any suggestions? btw im 70,000, time for new timing belt i know!
Jan 30, 2007 - 12:01 AM |
the easy stuff:
oil and filter change, spark plugs, wires, distributor cap and rotor, air filter, pcv valve, and check to make sure all your fluids [p/s, brake, clutch, tranny] are full and clear if you want to go further (more expensive things that are most likely unnecessary): coolant flush and fill, fuel filter, change all the belts including the timing belt, thermostat, water pump thats all I can think of right now... I'm sure theres more to be added -------------------- |
Jan 30, 2007 - 11:22 AM |
Enthusiast Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
QUOTE(hurley97 @ Jan 29, 2007 - 11:01 PM) [snapback]522504[/snapback] the easy stuff: oil and filter change, spark plugs, wires, distributor cap and rotor, air filter, pcv valve, and check to make sure all your fluids [p/s, brake, clutch, tranny] are full and clear Anyone have any tips on how to pull that PCV valve out without breaking it off in the valve cover? I've tried leaning on it pretty hard, and I stopped for fear of snapping it. |
Jan 30, 2007 - 10:58 PM |
QUOTE(94GT @ Jan 30, 2007 - 11:22 AM) [snapback]522625[/snapback] QUOTE(hurley97 @ Jan 29, 2007 - 11:01 PM) [snapback]522504[/snapback] the easy stuff: oil and filter change, spark plugs, wires, distributor cap and rotor, air filter, pcv valve, and check to make sure all your fluids [p/s, brake, clutch, tranny] are full and clear Anyone have any tips on how to pull that PCV valve out without breaking it off in the valve cover? I've tried leaning on it pretty hard, and I stopped for fear of snapping it. it should just pull right out, then theres that little clip on the hose. theres nothing else really holding it in there. -------------------- |
Jan 31, 2007 - 1:42 AM |
Okay, I'll try it again. I was trying to pry it out with a flat blade screw driver and I thought it might snap. I guess mine's just in there extra tight. Thanks for the help!
-Mike |
Jan 31, 2007 - 2:23 AM |
Enthusiast Joined Dec 8, '04 Currently Offline Reputation: 0 (0%) |
This post has been edited by BLADDER_MASTER: Nov 13, 2012 - 2:46 PM |
Jan 31, 2007 - 8:25 AM |
you should consider replacing your oxygen sensor also.
Lo-Fi Version | Time is now: January 10th, 2025 - 4:56 AM |
