HKS electronics |
HKS electronics |
Jan 31, 2007 - 6:03 PM |
Enthusiast Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) |
I bought a HKS SLD for my swap. Will this add HP ? or is it just to cut out factory speed limit of 180KMH ? Was it worth the 125$ I don't know now. I think it was just a waste of money.
Jan 31, 2007 - 7:08 PM |
Sorry, waste of money. It will only raise your speed limiter and unless you're being limited by your trap speeds I see no use for it. An FCD would have let you raise the boost but I wouldn't ever buy one since you can make those pretty easily:
http://www.alltrac.net/mods/fuelcut.htm -------------------- Project ST204.5 99.88946% complete... |
Jan 31, 2007 - 8:49 PM |
You know I thought it was not worth the money. I should have put that 125dollars for something else
Mar 15, 2007 - 7:01 PM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(WannabeGT4 @ Jan 31, 2007 - 7:08 PM) [snapback]523163[/snapback] Sorry, waste of money. It will only raise your speed limiter and unless you're being limited by your trap speeds I see no use for it. An FCD would have let you raise the boost but I wouldn't ever buy one since you can make those pretty easily: http://www.alltrac.net/mods/fuelcut.htm I skimmed over the link above. Is this the best way to raise your fuel cut and increase boost? Has anyone tried the $20 adjustable fuel cut defenders on ebay? These should be the same thing except ready to go. Right? |
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:51 AM |
