pretty sure its the cv joint but i figured id ask, clicking when i turn and accel. |
Feb 1, 2007 - 10:46 PM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
i have a click that has gotten progressively louder in my drivetrain some where. It sounds like its coming on the pass. side.
n e it clicks only when im on the accelerator and im turning. when im going straight it doesnt make any sound only when i turn or i go over a hump and my suspension travels up minimizing the weight on the wheels. |
Feb 1, 2007 - 11:24 PM |
CV joint, I had that problem with my old 1987 GT.
Feb 2, 2007 - 1:48 AM |
Enthusiast Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
with several of my experiences with them. It could be your axle, hub bearings, or your actual hub. Take the hub assembly out and see if your hub wiggles or move about. If not it's your axle. When reinstalling your axle make sure you torque it to the right spec or else if you over torque it, you will crush your hub bearing and under torqueing it could be just as bad as overtorqueing.
-------------------- <--- I miss :'' (
Lo-Fi Version | Time is now: November 29th, 2024 - 5:11 AM |
