Enthusiast ![]() Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) ![]() |
I was wondering, after the downpipe, what are the exhaust sizes you guys are running? currently im having 2.5" downpipe with 2" all the way back to muffler. wondering should i upgrade it
yup, OOBE has a 7afte A/T
QUOTE(Batman722 @ Feb 2, 2007 - 12:36 AM) [snapback]523338[/snapback] Hm... based on his spec, he is using 2.5". Does it affect alot on his low end? I do have impression that the low end is going to suffer alot |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(normality78 @ Feb 2, 2007 - 12:52 AM) [snapback]523343[/snapback] QUOTE(Batman722 @ Feb 2, 2007 - 12:36 AM) [snapback]523338[/snapback] Hm... based on his spec, he is using 2.5". Does it affect alot on his low end? I do have impression that the low end is going to suffer alot i have a turbo auto 7afe and if you are running a turbo i would not run any thing less than 2.5" as your turbo wont be able to spool right , it is like trying to push air through a straw the bigger the straw the easier it is , as far as the loss down low your turbo will make up for that as it will give you boost sooner ![]() ![]() -------------------- ![]() |
hm... tks for all the feedback. perhaps i shld try it out
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:35 PM |
