what differen between 3sge and 3sgte camshaft |
Feb 2, 2007 - 11:32 AM |
Enthusiast Joined Mar 30, '05 From Wisconsin Currently Offline Reputation: 0 (0%) |
i just like to ask but i was just wondering about the camshaft.
can the 3sge camshaft work on 3sgte head.. do i have to adjust to valve.. cuz i plan to use the 2nd 3sge camshaft on my 3sgte head.. i just like to ask can the 3sge get me more air flow them the 3sgte camshaft... just need some advice before i star doing my switch... |
Feb 5, 2007 - 9:33 PM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
hmmm, depends on what gen 3sgte you have.....i think that from what u have said, u could use those cams that you have on the seocnd gen 3sgte only...hmmm, i know that on mr2oc.com, they have alot of guidance on it....try hitting up that site....anywho, good luck ^_^
This post has been edited by 3WayStunna: Feb 5, 2007 - 9:33 PM -------------------- (\__/)
Feb 5, 2007 - 9:50 PM |
all I found was this
the 3sge compared to the 3sgte camshafts QUOTE(scothaniel @ Feb 2, 2007 - 4:01 PM) [snapback]523515[/snapback] The GE camshafts have a slightly longer duration, so you'll gain a little power. Very minor compared to a set of aftermarket cams. taken from this thread http://www.6gc.net/forums/index.php?showtopic=41160 -------------------- |
Feb 7, 2007 - 8:55 PM |
1st gen 3SGE/GTE cams can ONLY be changed for the same gen engines.
2nd and 3rd gen 3SGE/GTE are interchangeable between each other. GE has longer duration than GTE cams, so they can be a cheap upgrade. It all depends on how much you are willing to pay for them. You ALWAYS have to reshim if you change the cams in the engine. Good time to go to the shimless conversion from the ZZ engines. -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 5:50 PM |
