> question about LSD, PLEASE HELP!!!
post Feb 3, 2007 - 7:32 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Can someone confirm that when you turn an axle on a MR2 LSD, the other axle will spin the same direction. And on an open diff. they will spin opposing each other.
post Feb 3, 2007 - 9:21 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(toyotacrazy @ Feb 3, 2007 - 4:32 PM) [snapback]523728[/snapback]
On the VLSD, there is a good chance that they axles will still spin in opposite directions. The reliable way to tell if you have the stock LSD is to look through the diff - if there is a bar there, its the VLSD, if you can see right through, its open.
I have a KAAZ LSD - and it definitely keeps both axles spinning the same direction (and you use non-LSD axles with the KAAZ LSD).
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Feb 6, 2007 - 11:24 PM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(phattyduck @ Feb 3, 2007 - 9:21 PM) [snapback]523740[/snapback]
-Charlie
On my VLSD both axles turn the same way when done by hand. It's so fricken nice though.. I got the passenger tire on solid ice the other day.. driver side on dry ground.. Couldn't even notice I was on ice.. I gave it gas and it just moved straight no problem.
87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
post Feb 7, 2007 - 6:19 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Punisher @ Feb 6, 2007 - 11:24 PM) [snapback]524603[/snapback]
-Charlie
Are you sure that isnt a locking diff?
post Feb 9, 2007 - 1:04 AM
Punisher
Joined Jun 19, '06
From Portland, OR
post Feb 9, 2007 - 6:35 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
From what Ive researched about mr2 transmissions, theres locking diff, vlsd, and open diff. The locking will always spin like you stated your does. The vlsd will only work in the car when pressure is applied to the diff. And the open diff. is just open. I guess Ill find out about the vlsd when I get mine in the car. later
post Feb 11, 2007 - 9:00 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I just got my 1991 e-153 mr2 transmission today! I also got the jack shaft and axles. I paid $480 total and picked it up locally. I still am not positive it has vlsd. But I think it is. I put a few links to pics of the diff. Can anyone tell me if its vlsd or open diff??/?????
I put the clutch disc over the input shaft and spun the disc. The diff spun both axles in the same direction! If I held one stationary, they both tried to spin and also in the same direction. If I spun the axle by hand sometimes the axles spun together and sometimes they spun opposite. Thanks for any help! I wont know for sure if its lsd until I get it in the car. Later!!!!!!!!!!!!!!
trans
My Webpage
My Webpage
My Webpage
My Webpage
post Feb 12, 2007 - 1:14 AM
Punisher
Joined Jun 19, '06
From Portland, OR
If you hold one axle and turn the input shaft both shafts should turn the same way..
i'm betting it's a VLSD trans.
post Feb 12, 2007 - 1:24 AM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(toyotacrazy @ Feb 11, 2007 - 6:00 PM) [snapback]526025[/snapback]
The VLSD only became an option in '93. The pics you posted are of a tranny with an open diff (you can see through the center of the diff).
-Charlie
post Feb 12, 2007 - 2:15 AM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(phattyduck @ Feb 12, 2007 - 1:24 AM) [snapback]526095[/snapback]
-Charlie
My VLSD looks exactly like his and it is a VLSD...
post Feb 12, 2007 - 6:19 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Punisher @ Feb 12, 2007 - 2:15 AM) [snapback]526102[/snapback]
-Charlie
Sweet. I was hoping to hear that! Thanks!
post Feb 12, 2007 - 2:45 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(Punisher @ Feb 11, 2007 - 11:15 PM) [snapback]526102[/snapback]
Hmmm... that still doesn't explain the fact that the VLSD option from Toyota was not available until '93, as far as I know.
It may still be another type of LSD though...
-Charlie
post Feb 12, 2007 - 6:46 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
could it be a dealer added lsd?
post Feb 12, 2007 - 10:12 PM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(toyotacrazy @ Feb 12, 2007 - 6:46 PM) [snapback]526263[/snapback]
Most likely someone before you put an LSD in it. I know that if i have the car up on stands and i turn one wheel... the other turns in the same direction. When I was working with the open diff.. holding it in my hand I put finger in one side turned it and the other side went the opposite direction.
Some diff's won't lock up until there is a force applied like when driving..
The only way to truly test it I believe.. would be to put the front end up.. make sure u use a lot of jack stands under and on the sides of the car.. then start it.. put it into first gear.. you can let the clutch up and the wheels will just turn with the engine.. it won't stall. So get out then and try to stop one of the wheels with your hand.. don't be dumb about this obviously.. but on an open diff you will be able to stop one while the other still turns.. on an LSD you shouldn't be able to do this. Correct me if I'm wrong.. I usually learn things by trying and I've never tried to do that because I knew I had a VLSD to begin with.
Lo-Fi Version Time is now: February 24th, 2025 - 11:32 AM
