> F.S. ST205 motor mounts! Parting 5s-fe ENGINE, ADDED MANY 5s-fe parts and 3s-gte parts
post Feb 3, 2007 - 9:18 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Im selling this spec stage 2 clutch because Im going to convert my celica to a e-153 trans. This clutch is made for the s54 trans. splines and the disc is larger for the 3sgte pressure plate and flywheel. It only has 700 miles on it! Ill take best offer. Nothing wrong with it. It feels great and grabs when you put the power to it! Its a very streetable/strip clutch. The only reason Im selling it is my s54 broke 5th gear. The only part number on the box I can see is STD622. Needs to go! Pm me offers. Thanks
UPDATE: Selling all extra 5s-fe parts. IF YOU NEED SOMETHING LET ME KNOW. I MAY HAVE IT!
All 5s-fe parts came from my 95 celica gt. Ran great no check engine light.
List so far:
1. spec hybrid kevlar clutch PRACTICALLY NEW!!!!!!(5s-fe splines and 3sgte disc) SOLD
2. 5s-fe igniter (89621-26010) BEST OFFER
3. 5s-fe coil (90919-02163) BEST OFFER
4. 3s-gte ECM (89661-2b280=91/08-93/09) $100 shipped SOLD
5. 5s-fe ECM manual trans. $50 shipped
6. 5s-fe uncut engine harness SOLD
7. EXEDY 5s-fe flywheel, pressure plate, disc. 10K on all BEST OFFER(looks like new) SOLD
8. engine 180,000 miles ALL but block and head avalible.
9. Anything on engine (sensors, egr, hoses, distributor, throttle body, vsv's, ect.)
10. Alltrac transmission/transfer case $200
11.5S-FE distributor $40 shipped
12. ST205 rear motor mount minus bracket. (mount is bent as showed in picture but repairable with poly inserts) HARD TO FIND BEST OFFERmount
13. ST205 trans. side top mount MAKE OFFERmount
14. ST185 trans. side top mount and bracket MAKE OFFER
15. Right hand drive ST205 shifter assembly(NO CABLES) MAKE OFFERshifter
16. ST205 motor mount (timing cover side) MAKE OFFER
17. ST205 front motor mount MAKE OFFER
This post has been edited by toyotacrazy: Mar 14, 2007 - 6:43 PM
post Feb 3, 2007 - 9:27 PM
Speedy2k
Joined Jan 6, '06
From Toronto, Canada
Was the clutch properly broken in? How did you drive these 700 miles?
post Feb 3, 2007 - 9:42 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I was only running 6-7 psi of boost for the first 500 miles. I didnt slip it or speed shift it or slam it into gear. After I hit 500-600 miles I turned the boost up to 10 psi. Thats when my transmission/5th gear slid off the end of the shaft. I already had problems with the trans. previously to the swap. Since I need a new trans. Im getting a lsd mr2 trans. Thanks
BTW: most of these miles were highway on my way to work.
This post has been edited by toyotacrazy: Feb 3, 2007 - 9:43 PM
post Feb 4, 2007 - 9:14 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Added more parts for sale. PM me if you need something for 5s-fe. I have some 3s-gte leftovers. later
post Feb 26, 2007 - 10:08 PM
koreanjoey
Joined Jun 5, '06
From Tacoma, WA
What's the current offer for the clutch?
post Mar 1, 2007 - 2:43 PM
super13jew
Joined Oct 13, '06
From palmetto,FL
money sent for the flyheel. check you pm too
post Mar 1, 2007 - 8:01 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
SOLD Kevlar clutch
This post has been edited by toyotacrazy: Mar 1, 2007 - 8:01 PM
post Mar 10, 2007 - 9:20 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(toyotacrazy @ Feb 3, 2007 - 9:18 PM) [snapback]523739[/snapback]
List so far:
6. 5s-fe uncut engine harness BEST OFFER
I added many st205 parts. Make me some offers. I need to get rid of this stuff!!!! I have a great feedback here, also 190 feedback score on ebay all 100%. Just for reassurance. Thanks for looking!
post Mar 11, 2007 - 12:02 AM
$50 shipped to 02879 RI
post Mar 11, 2007 - 2:58 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
$55 shipped!
post Mar 11, 2007 - 12:06 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Ill get the harness off tonight and weigh it. Any more bids?
B.T.W. The 8 pin a/c plug has been cut. Its the one inside the car near the blower motor. That is the only connector cut. Sorry
This post has been edited by toyotacrazy: Mar 11, 2007 - 12:06 PM
post Mar 11, 2007 - 8:18 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Ok the package would weigh about 11 LBS. Shipping to 02879 is $15.00. Shipping to California is $22.00. So the bids are about even. Ill go with the first one unless I get a better offer soon. Thanks
post Mar 11, 2007 - 9:13 PM
LewFX
Joined Jan 28, '05
$60 shipped? im gonna need it to send to the doc for my beams project
post Mar 11, 2007 - 10:20 PM
Jeff, you can have it.
post May 10, 2008 - 12:19 AM
trdwasiq
Joined Aug 15, '07
From ATLANTA
still have the clutch?
KEEPIN IT LOW... WAP PRODUCTIONS... www.myspace.com/waprod
Lo-Fi Version Time is now: November 27th, 2024 - 3:50 AM
