> spec stage 2, is it toast?
post Feb 6, 2007 - 12:26 AM
6strngs
Joined May 12, '06
From Wilmington, NC
so, I just recieved a G-tech performance meter and I put it in and went to go take my car out for some test runs. I went out to these really long straight back roads that nobody is ever on and gave it 4 or 5 hard runs. but by the third run my brand new-ish spec stage 2 clutch (only 3,000 miles on it!) started slipping in second. and the next run it slipped into 2nd and 3rd. and while I was driving it home it slipped a LOT! and by I mean A LOT!!! like, just cruising in any gear at 25% throttle, just pressing the gas down slightly to, say, 50% throttle and it would slip for a while before catching. could my new clutch really be gone already? I mean, I broke it in 500 miles before pushing it, but I have driven it kinda hard since then. I bought the stage two so I could have something that would hold up to the power I plan on after I turbo, but if it can't even hold up to a near-stock 5sfe's power... anyway, anybody know what spec's warranty is like? I can't seem to find the piece of paper they sent me with the clutch. I'm most scared that even if the clutch is gone and they send me a new one for free that I'm still going to have to pay another $760 labor to get it installed... again!
post Feb 6, 2007 - 4:27 PM
6strngs
Joined May 12, '06
From Wilmington, NC
ok, so I drive it work today and it acts normal! wtf? does anyone know what this could mean?
post Feb 6, 2007 - 7:44 PM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
Not quite sure what could be going on. The only thing I can think of is that some oil might have got on the clutch and it was burning it off. Is your clutch stock or aftermarket?
post Feb 6, 2007 - 7:47 PM
your clutch pedal might be out of adjustment or you have an oil leak somewhere thats causing the clutch to slip
This post has been edited by lagos: Feb 6, 2007 - 7:48 PM
post Feb 6, 2007 - 9:24 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(95CelicaRacer @ Feb 6, 2007 - 4:44 PM) [snapback]524518[/snapback]
it is aftermarket. a spec stage 2.
I do have some kind of oil and/or transmission fluid leak. but I have no idea where it's leaking from. anybody know how to locate a leak?
post Feb 7, 2007 - 8:10 AM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
What I meant to say was is it a 6 puck clutch or is the clutch disc solid? If you want to locate where the leak is coming from you can dye the engine and use a black light to find where the leak is at.
post Feb 7, 2007 - 9:03 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
spec stage 2's are full faced disks
post Feb 7, 2007 - 4:19 PM
jcbass7
Joined Apr 20, '06
From Florida
thats a spec stage 2^^^
PS: thats the hybrid kit for the GT tranny and 3s engine
This post has been edited by jcbass7: Feb 7, 2007 - 4:20 PM
post Feb 7, 2007 - 10:49 PM
toyotatech
Joined Jun 14, '05
From colorado
check the clutch paedal adjustment
post Feb 7, 2007 - 11:12 PM
QUOTE(6strngs @ Feb 6, 2007 - 9:24 PM) [snapback]524564[/snapback]
check your distributor seal to see if anything is leaking from there. if that checks out, then there is a good chance that your rear main seal is leaking and causing the problem.
post Feb 9, 2007 - 2:47 PM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
I know this is a little off topic, but I was wondering if the 5sfe crankshaft bolt holes where the fylwheel is bolted on to is straight through becuase if so, oil could be leaking through the bolt holes, and it could look like a rear main leak.
post Feb 9, 2007 - 2:52 PM
QUOTE(95CelicaRacer @ Feb 9, 2007 - 2:47 PM) [snapback]525463[/snapback]
no, they are not. the only thing in that area is the rear main seal.
post Feb 9, 2007 - 2:56 PM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
Thanks for the info, Cause mine leaks from around that area. Now I have narrowed it down to the rear seal. smile.gif
post Feb 9, 2007 - 7:19 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(lagos @ Feb 7, 2007 - 8:12 PM) [snapback]524924[/snapback]
well, I pulled my distributor cap off today and there was oil around the edge on the bottom of it. does this mean my distributor seal is leaking?
post Feb 10, 2007 - 2:52 PM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
It is possible. However, did you check to see if the o-ring could be leaking also?
Lo-Fi Version Time is now: April 23rd, 2025 - 4:47 AM
