> subs don't work, death by electricution?
post Feb 6, 2007 - 6:57 PM
chandy1986
Joined Mar 23, '06
From Mass
I just got my car back from the shop and she is looking superb biggrin.gif. I just hooked up my subwoofers to the why they were when I disconnected them. I accidently set off a spark when I was connecting the power wire. I think it sparked because I touch the power to the ground and it set off a spark. With this said would my subs not work if the amp is fried?
post Feb 6, 2007 - 7:00 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(chandy1986 @ Feb 6, 2007 - 11:57 PM) [snapback]524497[/snapback]
Sounds like you fried the amp but I didn't follow you 100%. Do you have an in-line fuse? are there fuses on the amp? Check those you might just get lucky. That's what they are for after all.
post Feb 6, 2007 - 8:18 PM
chandy1986
Joined Mar 23, '06
From Mass
The fuses are in the amps but i check those and they are not blown. so my amp is most likely fried? now i have a huge box taking up 85% of my trunk with no real purpose beside taking up space laugh.gif
post Feb 6, 2007 - 8:42 PM
Lovo
Joined Jan 8, '07
From Charlotte, NC
well if the fuses haven't blown then maybe the spark wasn't enough to even break the fuse... your amp should be working, in theory of course
post Feb 6, 2007 - 8:52 PM
chandy1986
Joined Mar 23, '06
From Mass
if i wanted to get this fixed where can i take it and how much do you think they would charge? i preferably would like to do it myself lol
post Feb 6, 2007 - 10:14 PM
D_Dawg
Joined Jul 22, '06
From San Antonio / georgetown, Texas
id check the fuse on the power wire. i sparked mine and blew it up one time.
post Feb 6, 2007 - 10:30 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
amp still turning on? There should be a light which would show whether it is on or going into protection mode.(red usually)
post Feb 6, 2007 - 11:25 PM
chandy1986
Joined Mar 23, '06
From Mass
hmmm i check the fuses on the amp but didn't check the fuse on the power line yet. thats probably the problem cuz i sparked my fog light wires like that b4 and the fuse blew lol. I'm sure if there is a light on the amp that tells if its on. I'll check it out tomorrow
thanks for the your help
This post has been edited by chandy1986: Feb 6, 2007 - 11:27 PM
post Feb 7, 2007 - 12:17 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
yea man... the fuse on the power line will be the first to blow... replace that and your good... this happened to me a couple times when i was stupid taking subs out awhile back... If this isnt it, take it to an audio shop and they will prob check it out for free and only charge u a small service charge to fix it, depending on the problem and if the amp is still good (which it should be)
This post has been edited by tim86: Feb 7, 2007 - 12:18 AM
post Feb 7, 2007 - 9:24 AM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(chandy1986 @ Feb 7, 2007 - 4:25 AM) [snapback]524604[/snapback]
That's what I meant by in-line fuse. Usually it will be on the amp's power wire just after the battery under the hood. That is what was supposed to blow in the sit you had. I have seen an amp blow and not the fuse before though so cross your fingers. Then your only problem will be getting a replacement fuse as they are usually huge versions of the blade type fuse our car uses and you will have to go to an audio shop to get one [buy an extra just in case wink.gif ]
I hope thats all it is.
Edit - Oh yeah. Make sure to replace it with the same amperage.
This post has been edited by Negative: Feb 7, 2007 - 9:25 AM
post Feb 8, 2007 - 10:24 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
QUOTE(chandy1986 @ Feb 7, 2007 - 12:25 AM) [snapback]524604[/snapback]
you should turn off any live source before working on electrical. I hope you find a blown fuse.
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
Lo-Fi Version Time is now: February 23rd, 2025 - 9:47 AM
