Brakes?, supra brakes |
Feb 15, 2007 - 4:14 PM |
QUOTE(trdproven @ Feb 13, 2007 - 6:02 AM) [snapback]526367[/snapback] Well, just to jump in here. Overall, if you change the necessary parts can you still convert it? You'll need a custom caliper bracket and a custom rotor. ALSO... the ST205 and mkiv Supra do not use the same caliper. The Supra caliper is unique to that car, while the Celica caliper is also unique to that car (although very very similar to the 4x4 Toyota truck calipers). Neither one will "bolt-on" to 6th gen non-SuperStrut Celicas. -------------------- "It's ok to be naked girl... I'm an artist!"
Feb 19, 2007 - 9:44 PM |
Enthusiast Joined Dec 24, '06 From jonesville Currently Offline Reputation: 4 (100%) |
just ordered some tha other day!! should b here 2morrow along w/ new KYB struts...thanx 4 tha info.
Feb 20, 2007 - 12:58 AM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
If you want to improve your stopping power, i highly stand begind my new set up. I have an st so i upgraded both front and back to gt Rotors/calipers. Obviously you could skip this step if you have a gt. I got a set of steel braided brake lines from Russel. Also i upgraded to slotted Rotora rotors in the Front only. Hawk pads, and i also used a sythetic DOT 4 brake fluid opposed to DOT3. its just a little bit more but it has a higher boiling point than DOT3 and therefore if you are constantly aplying the brakes, it is less likely to boil and give you that sloppy peddal feel. Stops WAAAYYY better than before. I think the main ingrediant was the brake lines. the pedal feels way stiffer and the brakes respond a lot better. Good with it!
Lo-Fi Version | Time is now: January 12th, 2025 - 9:48 PM |
