Enthusiast Joined Dec 15, '05 From Woodbridge Currently Offline Reputation: 0 (0%) ![]() |
I'm wiring an amp that needs to be wired to the stereo remote. My question is as the power ariel is wired to the stereo remote how do i also wire the amp to the remote ? Any help appreciated!
![]() Enthusiast ![]() Joined Dec 18, '06 From Bristol, UK Currently Offline Reputation: 0 (0%) ![]() |
The power aerial wire i THINK is pink/purple... the remote you want to connect the amp to is the (thin) blue wire (possiblly with a white line)
The problem is that that blue wire with white stripe is connected to that pink wire through a wiring block. If i disconect either the blue wire or blue with white stripe my ariel will not go up.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
sorry to avoid your question, But i dont think you should use the ariel signal wire.
what happens if you want to listen to a CD? your ariel will be down and so will your amp? That sound kinda pointless. I recomend you taping a 12 volt power from the ignition accessory switch. This way your amp will be on when your car is on. Worse case senerio you can hook up an addition switch to this wire also, so you can turn off your amp manually, and prevent you from accidently leaving the amp on while your car is off. |
Lo-Fi Version | Time is now: February 20th, 2025 - 12:15 AM |
