Enthusiast ![]() Joined Dec 3, '05 From San Jose, CA Currently Offline Reputation: 0 (0%) ![]() |
is it worth the extra ~$1000 for the st205 clip?? i know it has a bit more power, but would it be worth spending the extra? also, does the st185 have the same amt of potential? and one more question for reassurance: the st185 swap write up would b the same for an st205 right? the tranny, mounts shifter cables, etc......the whole swap?
This post has been edited by hashmaster52: Feb 10, 2007 - 8:24 PM |
Enthusiast ![]() Joined Oct 3, '02 From HOUSTON Currently Offline Reputation: 0 (0%) ![]() |
just about everything is the same as far as the swap goes except the wiring is a bit easier... and as far as the difference in price and all, you basically get a newer fresher motor at that... its just all depends on what you have available at the time because in the end, its just about the same
so r u saying they would both run about the same in the 1/4 mile??? i thought the st205 (3rd gen) wo0uld be a lot faster...
This post has been edited by hashmaster52: Feb 10, 2007 - 9:05 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) ![]() |
....st185 has a water to air top mount intercooler.
the st205 goes back to the inferior air to air top mount. Unless u plan on shelling out for piping and a nice FMIC, id just go with the st185. The numbers arent great enough to justify the extra $1k. Talk to Defgeph, Lagos, and even Presure2. they will give u PROS and CONS for both clips, and u can decided on your own. -------------------- ![]() Kawi Love |
QUOTE(devilsden97 @ Feb 10, 2007 - 9:05 PM) [snapback]525807[/snapback] ....st185 has a water to air top mount intercooler. the st205 goes back to the inferior air to air top mount. Unless u plan on shelling out for piping and a nice FMIC, id just go with the st185. The numbers arent great enough to justify the extra $1k. Talk to Defgeph, Lagos, and even Presure2. they will give u PROS and CONS for both clips, and u can decided on your own. doesnt the st185 have air to air and the r/c version has the water to air? i heard the st205 is the gen with all water to air. im gettin all confused now. lol |
u are correct...sorry, RC is water to Air, while the standard st185 has a2a....
and im 95% certain the st205 has a2a aswell. like i said. wait for some of the big hitters here to reply. and go by what they say. because they know there stuff. This post has been edited by devilsden97: Feb 10, 2007 - 9:17 PM -------------------- ![]() Kawi Love |
QUOTE(devilsden97 @ Feb 10, 2007 - 9:16 PM) [snapback]525812[/snapback] u are correct...sorry, RC is water to Air, while the standard st185 has a2a.... and im 95% certain the st205 has a2a aswell. like i said. wait for some of the big hitters here to reply. and go by what they say. because they know there stuff. no prob man ![]() |
QUOTE is it worth the extra ~$1000 for the st205 clip?? without a doubt, YES! -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
QUOTE(devilsden97 @ Feb 10, 2007 - 9:16 PM) [snapback]525812[/snapback] u are correct...sorry, RC is water to Air, while the standard st185 has a2a.... and im 95% certain the st205 has a2a aswell. like i said. wait for some of the big hitters here to reply. and go by what they say. because they know there stuff. so it would be fair to say that you are 95% wrong ST-205 has a water to air intercooler or am I 100 % wrong ? ![]() ![]() This post has been edited by Culpable04: Feb 10, 2007 - 9:46 PM -------------------- ![]() |
st185
air to air top mount ( MUST BE REPLACED WITH A FMIC) ct26 turbo 440 injectors Flapper Door AFM i made 247hp 270tq at the wheels. so its not a bad swap st205 WATER to air IC ( even better then the "RC" water to air unit) ct20b turbo 550cc injectors MAP based system potential to hit around 270-290hp on the stock turbo/injectors for only 1,000 bucks more, get the st205. if you cant find an st205 clip, then just go with the st185. either way youll have a quick car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(lagos @ Feb 10, 2007 - 9:53 PM) [snapback]525825[/snapback] st185 air to air top mount ( MUST BE REPLACED WITH A FMIC) ct26 turbo 440 injectors Flapper Door AFM i made 247hp 270tq at the wheels. so its not a bad swap st205 WATER to air IC ( even better then the "RC" water to air unit) ct20b turbo 550cc injectors MAP based system potential to hit around 270-290hp on the stock turbo/injectors for only 1,000 bucks more, get the st205. if you cant find an st205 clip, then just go with the st185. either way youll have a quick car. ct20b turbo is better than ct26? |
yes.
do some more research before you buy anything. you should at the very least have a good understanding of the basics. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) ![]() |
yes..i think ct20b is ball bearing? it spools faster than the ct26
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) ![]() |
random question: Would it be worth it to drop in an ST205 3S into an ST185 All-trac? Or should you just swap to the CT20B, up the injectors, and get a FMIC?
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
if you already have a good st185, then you would be better off just upgrading what you have.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) ![]() |
The st205 is MAP isn't it? I just hate messing with those MAF sensors. Seem like the really slow down the tunability. I think that alone would be worth $500.
![]() Enthusiast ![]() ![]() Joined May 6, '03 From Parma - Italy Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Culpable04 @ Feb 11, 2007 - 3:45 AM) [snapback]525822[/snapback] QUOTE(devilsden97 @ Feb 10, 2007 - 9:16 PM) [snapback]525812[/snapback] u are correct...sorry, RC is water to Air, while the standard st185 has a2a.... and im 95% certain the st205 has a2a aswell. like i said. wait for some of the big hitters here to reply. and go by what they say. because they know there stuff. so it would be fair to say that you are 95% wrong ST-205 has a water to air intercooler or am I 100 % wrong ? ![]() ![]() ST185: a2a ST185 RC: w2a ST205: w2a PS: I had the ST185RC, and now I have the ST205... so I know what I'm sayimg... ![]() QUOTE(block @ Feb 11, 2007 - 5:49 AM) [snapback]525846[/snapback] yes..i think ct20b is ball bearing? it spools faster than the ct26 No, it's not bb. QUOTE(Bigmeanbulldog55 @ Feb 11, 2007 - 6:55 AM) [snapback]525860[/snapback] The st205 is MAP isn't it? I just hate messing with those MAF sensors. Seem like the really slow down the tunability. I think that alone would be worth $500. Yes, ST185 are MAF based, and ST205 is MAP based.... I would buy 3rd gen only for this reason ! -------------------- Wolf_Tm (Parma;Italy) [Silat-Kali]
Celica Gt-Four ST205 Snowy White [full TTE/WRC/custom hw home built 3SGTE - 2.34kg/hp DynoDynamics] http://www.facebook.com/wolf.tm http://www.youtube.com/WolfTm250 ![]() PS:You have to know that your Dynojet Whp are false,and closer to other dynos FW hp. Please specify what dyno are your Whp from. |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) ![]() |
I would say it depend entirely on your "goal". For a typical swap and if you are planning to keep it relative stock or mild mod (~300 whp on FWD), I'd go with 3rd gen setup. It is easier to bring 3rd gen to that level without adding more stuff. The stock CT20B, W/A IC, 540cc/min injectors, ECU, head, are good enough for that kind of goal.
However, if you are planning to build the engine to support BIG power, high boost, huge turbo, reinforced/stoked bottom end, head, new intake/exhaust manifold, FMIC, there is no reason to spend more on 3rd gen. 2nd gen engine will do the job. The highest HP on 2nd gen stroked block I have seen is about 800 rwhp and 700 awhp on STS185. By the way, if you can get the 3rd gen for only $1000 more, don't hesitate. All goodies that come with it (IC setup, CT20B, 540cc injectors, MAP sensor, ECU) will worth the extra money you pay. -------------------- _Gary
![]() Enthusiast ![]() ![]() Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) ![]() |
In your case go with st205, for extra $1000 you get 300-320whp capable turbo, better and MAP based engine managment with fuel cut at 18 psi, better intake manifold, superior head with shim under bucket shims, better camshafts, stronger headgasket, 5mm bigger throttle body, better fuel system (fuel rail and 540 injectors), and aside from some gen3 block casting flaws it still better if you consider stronger rods, pistons, lower compression (maybe not better but safer), also relocated oil filter (easier access), far superior a2w intercooler, and probably few things i forgot. Aftermarket parts for gen3 are harder to come by in usa but alot of maintenance parts can be substituted for gen2 parts and gen3 has more plug and play ems options. That 1000$ can be EASLY made back by selling the turbo, intercooler, and injectors, in case you would upgrade to bigger turbo, fmic and bigger injectors. Also consider emissions, i passed with a stock sw20 gen3 in illinois but whatever place your in might check for egr or something similar.
Good luck! -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Lo-Fi Version | Time is now: February 23rd, 2025 - 5:52 PM |
