> Dropzones....yea yea yea lol
post Jul 12, 2003 - 12:00 AM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
Okay heres te situation.....i'm purchasing alot of crap for my Celica right now and DropZone coilovers are on the list.....OK
heres teh scenario....I want to instal drop zones but use stock shocks. I would want to lower it whenever I want but for the most part keep it at stock height. My question is that would it ride pretty much like before if I kept it at stock height but I have it at the same height.....what about lowering it just an inch? And what does "blowing out" the shocks mean....becasue I realyl dont wanan do that becasue im sure that Toyota wouldn't cover that under warrenty....I cant afford konis yet.....lol
Please help? =)
post Jul 12, 2003 - 12:25 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I would say go for a compromise and get Toms springs or Sportlines or something...unless of course you really want the adjustability, in which case i would imagine the dropzones would ride a little rougher than springs would, although usually it depends on your shock condition, and how low you decide to set them at as to what your ride quality will be.
post Jul 12, 2003 - 12:29 AM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
stock to 1 inch....nothing more for street......for show....drop em down
watcha think?
-Nate
post Jul 12, 2003 - 12:32 AM
Silver94CelicaOw...
Joined Oct 13, '02
Im sure it would work and ride fine, as long as you dont mind the slight sacrafice in ride quality the rest of the time you drive.
post Jul 12, 2003 - 1:09 AM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
How much is "slight" and how about my shocks? I need them to last a long time....will they last as long as they normally would or no? Thanks alot
post Jul 12, 2003 - 1:35 AM
Silver94CelicaOw...
Joined Oct 13, '02
By slight i just meant maybe some extra bounciness than you otherwise would normally have, like when you hit a heave in the road or a pothole or something. As far as shocks go, im sure they would wear a little faster if you had your celi dropped much lower than stock height, but as long as it isnt below like 2 inches you should be ok with your stock shocks ad not raise hell with them.....i personally dont have coilovers on, but this is just what ive gathered from all my time on here and other sites, and from what knowledge ive gathered from hanging around other more mechanically inclined people. wink.gif
post Jul 12, 2003 - 2:48 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
When I blew my struts out I really did blow them out. When I took the retaining nut off of the strut (the one that holds the strut cartridge in there) < fluid actually shot out. it did that on both of the front struts.
post Jul 12, 2003 - 5:05 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
My setup (before my car went into the shop):
Front: Custom made springs by Valley Springs in Dixon, CA -> 1.5" drop
Rear: H&R -> 1.3" drop
Struts: Factory all around
Rough? In the beginning, no. Before it went into the shop? Yes.
Solution: Just becareful where/how you drive. Try to avoid deep bumps and pot holes. My car was lowered in 95, and did well up until around 2001, which is when I started noticing my car bottoming out.
post Jul 12, 2003 - 1:13 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (kuya1284 @ Jul 12, 2003 - 2:19 AM)
Sounds normal to me Ray...;] Struts tend to fail after a few years of abuse...
Lowering your car on the stock struts should be fine so long as you can bare the bouncy ride. It will decrease the strut life, but as Ray points out, it's not a huge major deal... the struts still should last a bit, IMO, even with coilovers slammin it.
On my old celica, I had some generic coilovers on it and had it slammed 90% of the time ( over 2" drop). My stuts didn't go out until I was being dump and spun out the car at thunderhills trying to hit a turn too fast and went off the track. That was back in 2000 and I had the car lowered since I bought it, in 97.
post Jul 12, 2003 - 2:25 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
I just need em to last for 5 years.....you think it would last that long? LoL
post Jul 12, 2003 - 3:29 PM
not with D/Z..its not gonna last...if you want ride quality, i'd stay away from the dropzones..check out ground control..
post Jul 12, 2003 - 3:34 PM
kuya1284
Joined Nov 15, '02
Nate: Personally, I think you should just stick with springs. They're good enough for your application.
post Jul 12, 2003 - 3:42 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
Which springs?
post Jul 12, 2003 - 3:44 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
I can't afford ground controls.....at least I don't think.....
post Jul 12, 2003 - 3:53 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
Personalyl I dont mind how low it is in front....its jsut the rear...I jsut want it lowered about an inch....nothing more......and springs unless they are TRD.....lower too much..tahts why I figured DZ coilovers..so I could adjust them when I need to...
post Jul 12, 2003 - 4:46 PM
Silver94CelicaOw...
Joined Oct 13, '02
I would think that if you liked that dropped look for show, you would wanna have it look that way all the time, and once it is dropped, you'll probably think it looks kinda dumb when its raised back up to stock height again and just keep it dropped......in which case you could just get yourself some nice springs and it'll do the job- youre shocks wont get killed, and your car will look alot better if you want that dropped look. I would reccomend Tom's springs.....1.5 in the back, and 1.75 in the front, that sounds about where you wanted them anyway, so i would go that route if i were you. wink.gif
EDIT- Plus, toms springs are cheaper than DZ's anyway.....98 bucks at racer wheel
This post has been edited by Silver94CelicaOwner: Jul 12, 2003 - 4:48 PM
post Jul 12, 2003 - 4:48 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
Wait I dont get it....woudlnt it be the same if I had coilovers instead of springs....the only difference them beign adjustable?
post Jul 12, 2003 - 4:53 PM
Silver94CelicaOw...
Joined Oct 13, '02
Im pretty sure that coilovers seat differently due to the adjustability, or something......someone correct me if im wrong, there wink.gif but im pretty sure thats correct, and in result of the different seating they tend to generally ride a little less tame as springs would. But yeah, look at the Tom's springs, i just edited my last comment to show you what i was talking about. I would go springs since your main objectives in all this seem to be preserving your shocks but getting a nice drop look. I say forget about adjustability, you dont need it in Cali anyway.....and once you drop you probably wont wanna adjust them all the time. biggrin.gif
post Jul 12, 2003 - 5:00 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
How low would it be..and how bouncy? Because my parents like the car adn they try to drive it sometimes.....they took my keys and made a copy so they coudl drive it LOL
post Jul 12, 2003 - 5:15 PM
XE_Nathaniel
Joined Mar 14, '03
From Long Beach, CA
Maybe I should instal the kit first and see if I want to drop it...
Lo-Fi Version Time is now: February 23rd, 2025 - 4:17 PM
