> I need new piston rings :(
post Feb 12, 2007 - 4:29 PM
fanboy95
Joined Feb 26, '06
From Illinois
My piston rings are bad and i'm burning oil. I'm tired of my white car having a black rear end, where i have to wash it ever week to keep it looking desent. Does anyone know roughly how much a shop might charge to fix it?
post Feb 12, 2007 - 4:35 PM
have u done a compression and leak down test..?
post Feb 12, 2007 - 4:55 PM
fanboy95
Joined Feb 26, '06
From Illinois
no, my girlfriends brother is a mechanic and he checked it out though.
post Feb 12, 2007 - 5:00 PM
lol i laugh
any good mech knows to do a compression + leak down test before claiming rings...
cause valve seals will do the same thing
post Feb 13, 2007 - 12:20 PM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
Say if it was that the rings were bad, your looking at about $500-$700 depending on the mechanic you go to. frown.gif However, you may be able to save some money if you get the parts yourself. rolleyes.gif
post Feb 14, 2007 - 2:10 PM
alltracman78
Joined Aug 9, '06
From Ma
Normally it's the cylinder bore and not the rings that wear.....
So IF you have ring leakdown, you're probably looking at a cylinder rehone at minimum, probably a rebore, not just replacing the rings.
But yes, valve seals also will cause oil burning, and are MUCH more common to go bad.
post Feb 14, 2007 - 2:25 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
Take the oppertunity to just do an engine swap. =]
post Feb 14, 2007 - 3:03 PM
fanboy95
Joined Feb 26, '06
From Illinois
QUOTE(tin_foil @ Feb 14, 2007 - 2:25 PM) [snapback]526856[/snapback]
Yeah thats what i would like to do but i'd have to save for awhile.
post Feb 14, 2007 - 4:20 PM
i think your girlfriends brother gave you an incorrect diagnosis.
post Feb 15, 2007 - 10:46 PM
QUOTE(alltracman78 @ Feb 14, 2007 - 2:10 PM) [snapback]526853[/snapback]
if you replace rings you have to rehone newayz
Lo-Fi Version Time is now: November 24th, 2024 - 9:25 PM
