![]() Enthusiast ![]() ![]() Joined Jan 23, '05 From Portage Currently Offline Reputation: 5 (100%) ![]() |
I need one i don't care how many miles are on it as long as it works. Mine got thrown around during my rebuild and got damaged. ohhh and urbandork you never got back to me about yours hence this post.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Crank or cam sensor?
The Celica 5S never had a crank sensor. It only uses the dist for cam timing. The Camry had a crank sensor in the 97 ^ I believe. -------------------- ![]() |
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) ![]() |
QUOTE(alltracman78 @ Feb 15, 2007 - 8:23 PM) [snapback]527263[/snapback] Crank or cam sensor? The Celica 5S never had a crank sensor. It only uses the dist for cam timing. The Camry had a crank sensor in the 97 ^ I believe. True. Im parting out a 95 gt engine if you find out what you need. |
i believe it's a crank sensor it plugs into the oil pump. and my 96 manual (toyota BGB) specificly states crank positioning sensor and i don't believe that'd be wrong but hey it might. anyways that doesn't change the fact that i need one.
This post has been edited by AllTrac96: Feb 16, 2007 - 2:41 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
94-95 BGBs don't mention a crank sensor. 96-99 BGBs all say that the 5S has a crank sensor. I have to admit I was under the impression that they didn't have one either but all four books mention it.
This post has been edited by WannabeGT4: Feb 16, 2007 - 8:54 AM -------------------- ![]() Project ST204.5 99.88946% complete... |
okay so it is established that the 5s has one then correct? now back on topic i need a crank position sensor! does anybody have one that is in working condition?
No sorry. I know the camry started using a crank sensor in 96. Mines a 95
Lo-Fi Version | Time is now: February 19th, 2025 - 9:46 PM |
