![]() Enthusiast ![]() Joined Feb 8, '07 From Oakland, Ca USA Currently Offline Reputation: 0 (0%) ![]() |
I have a wiring harness that I bought a few weeks ago to install a head unit in my car. This was before I knew I had a factory amp. So its now useless to me, since I got an amp integration harness instead.
Im offering it free to anyone who wants to come pick it up. Not worth shipping, unless someone really wants to pay the shipping cost, but they could get one locally for under 10 bucks. Im located in Oakland ca. -------------------- -M-
Bumpity bump....
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) ![]() |
QUOTE(Manny @ Feb 15, 2007 - 1:02 PM) [snapback]527115[/snapback] Bumpity bump.... where are u located? |
QUOTE(azn87 @ Feb 15, 2007 - 7:18 PM) [snapback]527127[/snapback] QUOTE(Manny @ Feb 15, 2007 - 1:02 PM) [snapback]527115[/snapback] Bumpity bump.... where are u located? Oakland.... -------------------- -M-
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
you know, the wiring harness will still work. I had the same problem. basically, there's a little silver box under your climate control that is your stock amp, and underneath there is a little hidden wiring thing-a-ma-jig that the wiring harness will plug right into. so you don't need to cut and splice all the wires. check out this how-to:
http://installdr.com/InstallDocs/Toyota/PDF/869009.pdf btw, I don't think you should still use your stock amp. I think I remember reading on here somewhere that somebody did and complained that it was waayy too loud all the time, even with the volume really low. This post has been edited by 6strngs: Feb 15, 2007 - 2:29 PM -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
QUOTE(6strngs @ Feb 15, 2007 - 7:28 PM) [snapback]527131[/snapback] you know, the wiring harness will still work. I had the same problem. basically, there's a little silver box under your climate control that is your stock amp, and underneath there is a little hidden wiring thing-a-ma-jig that the wiring harness will plug right into. so you don't need to cut and splice all the wires. check out this how-to: http://installdr.com/InstallDocs/Toyota/PDF/869009.pdf btw, I don't think you should still use your stock amp. I think I remember reading on here somewhere that somebody did and complained that it was waayy too loud all the time, even with the volume really low. I got it all set up already... Used an amp integration harness.... I still wanted to take advantage of all 8 speakers, and I cant do that without an amp to properly deliver to signals. It actually sounds really good, with some tweaking... I have a real good head unit with a whole lot of audio fine tuning features. I am still fine tuning it, usually takes me a couple of weeks to find a good balance since i listen to all kinds of different music. I'll show it to you saturday. -------------------- -M-
can u bring it to me on saterday?? for the dyno day. thanx
QUOTE(Manny @ Feb 15, 2007 - 11:33 AM) [snapback]527133[/snapback] QUOTE(6strngs @ Feb 15, 2007 - 7:28 PM) [snapback]527131[/snapback] you know, the wiring harness will still work. I had the same problem. basically, there's a little silver box under your climate control that is your stock amp, and underneath there is a little hidden wiring thing-a-ma-jig that the wiring harness will plug right into. so you don't need to cut and splice all the wires. check out this how-to: http://installdr.com/InstallDocs/Toyota/PDF/869009.pdf btw, I don't think you should still use your stock amp. I think I remember reading on here somewhere that somebody did and complained that it was waayy too loud all the time, even with the volume really low. I got it all set up already... Used an amp integration harness.... I still wanted to take advantage of all 8 speakers, and I cant do that without an amp to properly deliver to signals. It actually sounds really good, with some tweaking... I have a real good head unit with a whole lot of audio fine tuning features. I am still fine tuning it, usually takes me a couple of weeks to find a good balance since i listen to all kinds of different music. I'll show it to you saturday. alright. well, I think most head units already have a built in amp. which is why the other guy's sound was too loud because he was amplifying it twice. lol. but if you've got it set up how you like it then by all means go for it! -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
QUOTE(6strngs @ Feb 16, 2007 - 6:51 AM) [snapback]527357[/snapback] QUOTE(Manny @ Feb 15, 2007 - 11:33 AM) [snapback]527133[/snapback] QUOTE(6strngs @ Feb 15, 2007 - 7:28 PM) [snapback]527131[/snapback] you know, the wiring harness will still work. I had the same problem. basically, there's a little silver box under your climate control that is your stock amp, and underneath there is a little hidden wiring thing-a-ma-jig that the wiring harness will plug right into. so you don't need to cut and splice all the wires. check out this how-to: http://installdr.com/InstallDocs/Toyota/PDF/869009.pdf btw, I don't think you should still use your stock amp. I think I remember reading on here somewhere that somebody did and complained that it was waayy too loud all the time, even with the volume really low. I got it all set up already... Used an amp integration harness.... I still wanted to take advantage of all 8 speakers, and I cant do that without an amp to properly deliver to signals. It actually sounds really good, with some tweaking... I have a real good head unit with a whole lot of audio fine tuning features. I am still fine tuning it, usually takes me a couple of weeks to find a good balance since i listen to all kinds of different music. I'll show it to you saturday. alright. well, I think most head units already have a built in amp. which is why the other guy's sound was too loud because he was amplifying it twice. lol. but if you've got it set up how you like it then by all means go for it! Yea.... I can set the output level on this head unit... just like setting the gain on an amp.... Since the factory amp doesnt have an option for adjusting gain... this works well.... Not great or perfect by any means... but good until I upgrade everything. QUOTE(azn87 @ Feb 16, 2007 - 6:42 AM) [snapback]527355[/snapback] can u bring it to me on saterday?? for the dyno day. thanx Yea... Ill bring it to applebees.... -------------------- -M-
Still got it.....
Still got it folks....
Lo-Fi Version | Time is now: February 25th, 2025 - 3:10 AM |
