2 bar map sensor |
2 bar map sensor |
Feb 15, 2007 - 2:59 PM |
Enthusiast Joined Sep 2, '05 From delaware Currently Offline Reputation: 0 (0%) |
hey guys i was just wondering if anyone knew the part number for the 3sgte 2 bar map sensor. iam doing a 5sfte and need toyota part number, and i was also told that it was considered a TPS (turbocharger pressure sensor) .
thanks |
Feb 15, 2007 - 5:54 PM |
Buy a used one from mr2oc.
-------------------- Project ST204.5 99.88946% complete... |
Feb 15, 2007 - 5:58 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
Yes, Toyota call it Turbocharger Pressure Sensor
You can use one from Celica Alltrac or MR2 Turbo The MR2 one is 89420-17030, "Sensor Assembly, Turbo Pressure" This post has been edited by Gary: Feb 15, 2007 - 5:58 PM -------------------- _Gary
Feb 18, 2007 - 5:31 PM |
QUOTE(Gary @ Feb 15, 2007 - 5:58 PM) [snapback]527211[/snapback] Yes, Toyota call it Turbocharger Pressure Sensor You can use one from Celica Alltrac or MR2 Turbo The MR2 one is 89420-17030, "Sensor Assembly, Turbo Pressure" thank man i have been trying for days now to find it thanks |
Apr 3, 2007 - 4:42 PM |
Enthusiast Joined Mar 30, '05 From Wisconsin Currently Offline Reputation: 0 (0%) |
Or u can grand national map sensor too. they has the same wire diagram, and is has 3 bar on. boost from 1 PSI to 30 psi.. with out hitting fuel cuz.. cuz i know alot people who use this map sensor for their car... it only 86 dollar from auto zoner or u could go look online for more detail...u don't to wast $200 buck for 1.2 bar.. it so expensive..
and one my guy friend told about this grand national map sensor and i bought it. i use for it i didn't have to worry about fuel cut.. and i use a boost control. Or u can grand national map sensor too. they has the same wire diagram, and is has 3 bar on. boost from 1 PSI to 30 psi.. with out hitting fuel cuz.. cuz i know alot people who use this map sensor for their car... it only 86 dollar from auto zoner or u could go look online for more detail...u don't to wast $200 buck for 1.2 bar.. it so expensive.. and one my guy friend told about this grand national map sensor and i bought it. i use for it i didn't have to worry about fuel cut.. and i use a boost control. |
Apr 3, 2007 - 8:33 PM |
usually when people go w/ a 3-bar map sensor they get the GM one for $75.
hopefully u can find a used one on mr2oc for pretty cheap. i managed to sell my 1jz map sensor for $100, but i think i got lucky.(it's the same or VERY close to the same as SW20's) -------------------- |
Apr 4, 2007 - 1:18 AM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I bought one used at mr2oc.com for $68 shipped. they cost alot more than that brand new. and for a 5sfte, you'll probably never boost more than 2 bar anyway
This post has been edited by 6strngs: Apr 4, 2007 - 1:19 AM -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Apr 4, 2007 - 12:29 PM |
map sensors are in absolute.
so a 2-bar is really 1bar, and 3 bar 2... just clarifying. -------------------- |
Apr 4, 2007 - 3:29 PM |
QUOTE(Consynx @ Apr 4, 2007 - 10:29 AM) [snapback]543108[/snapback] map sensors are in absolute. so a 2-bar is really 1bar, and 3 bar 2... just clarifying. yeah, I was wondering about that. cause I thought 2-bar was like 15 PSI, but when I looked it up, it was really like 30 PSI... either way, a 2-bar map sensor is still good for up to 15-ish PSI which is alot for a 5sfte -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Aug 24, 2007 - 11:07 AM |
Enthusiast Joined Jul 17, '06 From Gig Harbor Currently Offline Reputation: 0 (0%) |
I and some others are intrigued about the grand national map sensor. Does it just plug right in to the stock location or is there some wiring involved? Sorry for the revival.
-------------------- QUOTE You can't spell overreacting without ovary. |
Aug 24, 2007 - 1:32 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
QUOTE(Rdizzle @ Aug 24, 2007 - 9:07 AM) [snapback]590401[/snapback] I and some others are intrigued about the grand national map sensor. Does it just plug right in to the stock location or is there some wiring involved? Sorry for the revival. what's a grand national map sensor? anyway, i was able to buy mine for 30. -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Aug 24, 2007 - 11:57 PM |
yeah the grand national map sensor, it pretty good..
i bought mine from ebay.. for 30 dollar, but it work. the wire u gotta look up for Buick motor diagram.. it save a little money and can u can boost higher.. 15-30 pis.. but ur engine has to built strong.. for it.. |
Aug 26, 2007 - 12:13 PM |
and u gotta be able to tune with it since the voltage output is going to be way off for a stock ecu
Aug 26, 2007 - 1:27 PM |
correct me if im wrong, but i thought the idea was, that if you double your injector size, you should also double the map sensor, so that the stock fuel map gets scaled correctly. putting a 3bar map sensor would be a bad idea because you would mess with the load readings of the stock ecu. stick to a 2bar map and 440 injectors, if you plan on running 7-15psi.
Aug 26, 2007 - 1:57 PM |
^interesting....
Aug 26, 2007 - 10:01 PM |
QUOTE(lagos @ Aug 26, 2007 - 11:27 AM) [snapback]590903[/snapback] correct me if im wrong, but i thought the idea was, that if you double your injector size, you should also double the map sensor, so that the stock fuel map gets scaled correctly. putting a 3bar map sensor would be a bad idea because you would mess with the load readings of the stock ecu. stick to a 2bar map and 440 injectors, if you plan on running 7-15psi. so stock injectors are 220cc? -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Aug 27, 2007 - 12:27 AM |
i THINK stock ones are 213s. manny could probably give you more info on that.
Aug 27, 2007 - 1:12 PM |
sounds like a ghetto way to run more boost to me, lol
since each sensor actually is a bit different with voltages, if the stocks are 213, then 440 might be okay, to be a little rich on the same side incase the voltage is off a bit. just whatever you do, it's always smart to have a wideband ready IMO -------------------- |
Aug 27, 2007 - 1:30 PM |
Enthusiast Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
QUOTE(lagos @ Aug 26, 2007 - 11:27 PM) [snapback]591138[/snapback] i THINK stock ones are 213s. Stock are 220cc at 3bar. Manny recommends the RX-7 Injectors, they are 460cc at 3bar. -------------------- |
Aug 27, 2007 - 1:36 PM |
QUOTE(Consynx @ Aug 27, 2007 - 2:12 PM) [snapback]591263[/snapback] sounds like a ghetto way to run more boost to me, lol since each sensor actually is a bit different with voltages, if the stocks are 213, then 440 might be okay, to be a little rich on the same side incase the voltage is off a bit. just whatever you do, it's always smart to have a wideband ready IMO i think all of these map sensor send out 0-5volts. the stock fuel map is from vac to 0psi. adding a 2bar map will just stretch out that fuel map, so that the ecu wont freak out when it sees boost. this way when your boosting 14.5psi (1bar) the stock ecu will see 100% load (a good thing). but if you tried the same thing with a 3bar map, the ecu would only see about 67% max load at 1bar of boost, throwing your timing maps WAY of. and yeah, the car will still need a wideband and a piggy back to tune it. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: November 27th, 2024 - 7:03 PM |
