2 Pages V  < 1 2
> 2 bar map sensor
post Aug 30, 2007 - 7:40 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i meant just to cope.
same reason another 2bar map isn't just swapped w/ another all the time, the voltages vary a bit.
s-afc ii has like 20???? different map sensor settings trying to account for all the difference logarithmic outputs they have.
not perfectly linear
post Sep 14, 2007 - 9:58 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
So let me get this straight real quick.
2 Bar Map Sensor with SAFC and Turbo Probe injectors will be fine?
I remember Nik ran stock 7a injectors for a while will they be fine at 7psi on ct26? SAFC no matter what.
12:1 FMU is what is stated but I remember quite some time ago (year or 2) it was stated 12:1 was higher than needed and 8:1 would work better. Anyone else remember that being brought up?
This post has been edited by Harold_Fastwaker: Sep 14, 2007 - 11:17 PM
post Sep 15, 2007 - 7:47 AM
QUOTE(Harold_Fastwaker @ Sep 14, 2007 - 10:58 PM) [snapback]596172[/snapback]
harold, if you have a ST, a ct-26 is not a good option for you.
it wont bolt up (like it does on a GT/5sfe)
stock 7a injectors are what ~210cc?
thats just looking for trouble, and the FMU is not much better.
think about it like this :
your stock fuel pressure is ~40 or so psi
with a 12:1 fmu, running 7 psi, your effective fuel pressure is now 124psi. LMAO.
the pressure accross the rail will be VERY inconsistant, exactly what you DONT want under boost.
sure, it may work for awhile...but its definetly not a long term solution.
post Sep 15, 2007 - 3:40 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE(presure2 @ Sep 15, 2007 - 8:47 AM) [snapback]596243[/snapback]
Oh Ok, so your saying that instead of running the 2bar map using Check Valves will make it last alot longer! laugh.gif
post Sep 15, 2007 - 4:51 PM
QUOTE(Harold_Fastwaker @ Sep 15, 2007 - 4:40 PM) [snapback]596306[/snapback]
umm....i dont know how you got THAT outta what i said..lol
post Sep 15, 2007 - 4:55 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE(presure2 @ Sep 15, 2007 - 5:51 PM) [snapback]596318[/snapback]
Im just bashing on you. Every check valve thread you pretty much destroy anyones attempt at using them. wink.gif
post Sep 15, 2007 - 6:06 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
IIRC the stock 7A injectors are 180cc
and a ct26 is just not right on a 7a, go with a t3 super 60.
-Brian
post Sep 15, 2007 - 9:09 PM
QUOTE(Harold_Fastwaker @ Sep 15, 2007 - 5:55 PM) [snapback]596320[/snapback]
bashing me? lmao
i dont see how any of this is helping the OP at all.
post Sep 16, 2007 - 12:54 AM
southwest2118
Joined Jan 13, '06
so second gen mr2 turbo map sensor would work on the 7afe?
will the connector also hook up w/ no problem???
what years are the second gen!!!11!!1!!oneone
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 17th, 2025 - 1:13 PM
