Enthusiast Joined Feb 9, '07 From Casselberry,FL Currently Offline Reputation: 0 (0%) ![]() |
ok, first off my name is ohmar, i drive a Nissan B13 sentra with a VVL in it and my G.F has a 6g celica GT. i want to know exactly what i would need to buy to swap in a 3sgte and make it work fine....i know the common fuel pump, and fuel management...my little touch for her, but what mounts, shift linkage, ECU, everything....
Thanks for the help, laters |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
Welcome to the site Ohmar. You can find all the information you need in the Forced Induction stickies.
Good luck and again welcome ![]() -------------------- ![]() I will return one day. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
welcome to the forums !
the info you're looking for is well spread on the engine section use the search funtion and you'll get more info than you're are looking for check this link to get you started. stickies -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
sry it took me a while to respond, but saw all the links and my god...thank's for the help....next time ill search more before i ask....but it was a quick question and i did look for a bit but apparently not long enough....anyways...thanks alot
Lo-Fi Version | Time is now: February 18th, 2025 - 12:42 AM |
