> Clear Headlight Lense, Gonna try to make one
post Feb 21, 2007 - 12:36 PM
LeonStryfe
Joined Mar 28, '06
From Brooklyn, New York
Hey guys do you know where I can get these lense http://lh5.google.com/image/ash.armstrong/....JPG?imgmax=512
I just need the high beams part, cause I'm gonna take a plastic clear glass, the same glass that they use in procar parts in our clear lense turn signal and mold (bake it and shape it) to the shape of that part they put to cover the headlight hole.
My plan if you can imagine it is to create a clear lense cover that would look like the picture above (only for high beams and its clear!) and put a angel eyes halo around the diameter of the inner circular area - outside diameter of the high beams.
Also if I can make this, I can most likely mass copy them and possible sell them to you guys if interested? This way its easier to install halos, in which we need not take off our bumper and heat our high beams.
post Feb 21, 2007 - 12:45 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
<<<<<< DCw / JDMart >>>>>>>
post Feb 21, 2007 - 12:59 PM
LeonStryfe
Joined Mar 28, '06
QUOTE(doGGy @ Feb 21, 2007 - 12:45 PM) [snapback]529046[/snapback]
O.o nevermind?
post Feb 21, 2007 - 1:02 PM
doGGy
Joined Oct 28, '02
QUOTE(LeonStryfe @ Feb 21, 2007 - 10:59 AM) [snapback]529050[/snapback]
O.o nevermind?
post Feb 21, 2007 - 3:24 PM
frosty
Joined Sep 1, '04
From Alabama
Do you have a different link? That one didn't work for me.
CLOSED on 25 acres!
-shop coming soon....
post Feb 22, 2007 - 11:16 AM
LeonStryfe
Joined Mar 28, '06
hmm clear lense headlight is doable also, maybe I can buy a headlight broken for cheap for me to play around with. that might even be a better idea.
Btw frosty search Celebrity celica and ull see the covers i want to make a clear lense out of
post Feb 22, 2007 - 3:59 PM
baddisintegra
Joined Nov 29, '06
From South Florida
how about taking off the lenses finding a glass grinding/sanding then polishing it so it looks clear, i dont know if you can sand glass though!
post Feb 22, 2007 - 4:01 PM
that won't work
post Feb 22, 2007 - 4:34 PM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
QUOTE(playr158 @ Feb 22, 2007 - 5:01 PM) [snapback]529414[/snapback]
that won't work
Oh yea? I've seen it done in person so please elaborate
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Feb 22, 2007 - 6:14 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(CilverSeliST205 @ Feb 22, 2007 - 3:34 PM) [snapback]529420[/snapback]
that won't work
post Feb 22, 2007 - 6:24 PM
you can't just sand them out...
i've done it before you'll never get them perfectly clear i've personnally taken a 6gc headlight and tried...you have to sand blast it or something i forget but its not just grinding and sanding..plus you arn't going to get a perfectly smooth/even surface by hand neways
This post has been edited by playr158: Feb 22, 2007 - 6:25 PM
post Feb 22, 2007 - 6:52 PM
LeonStryfe
Joined Mar 28, '06
sanding glass is a pain... I was thinking of a plexiglass that masked told me, might possible work..
post Feb 23, 2007 - 8:35 AM
baddisintegra
Joined Nov 29, '06
From South Florida
plexiglass mold is probably the best way, cheapest too
the glass can be sand blasted down, but the pain is polishing them i heard. probably difficult because of it being so uneven too after the sandblasting
i wonder if a heavy grit sanding disc could smoothen out the surface and just try to get someone to polish it
i know there is an art school around em and they do some glass work, they should be able to wok something too
post Feb 23, 2007 - 9:34 AM
creis
Joined Jan 10, '04
From Shoreline, WA
mold with plexi glass, glass sanding would be to much work for what your trying to do. plexi glass would be easy just heat it up and wrap it around then cut and sand edges.
post Feb 25, 2007 - 1:19 AM
LeonStryfe
Joined Mar 28, '06
QUOTE(creis @ Feb 23, 2007 - 9:34 AM) [snapback]529636[/snapback]
My thoughts exactly. BTW anyone has a pic of the inner OEM headlights?
Lo-Fi Version Time is now: November 27th, 2024 - 8:24 PM
