> Clutch?, clutch wouldnt engage
post Feb 23, 2007 - 1:43 AM
95celly
Joined Feb 22, '07
From Philadelphia
Yesterday i was driving about to merge onto I-95 when i noticed that i couldnt accelerate in any gear. I was in fifth going about 65 and when i accelerated the RPMs went up to about 5000 and the car wouldnt accelerate. I Put it into fourth and the same thing happened so i pulled onto the shoulder and turned the car off and back on. Then i put it into first and tried to merge back into traffic but the car wouldnt move. I shifted into first and the RPMs went up tp around 4 or 5k and the car just sat there. I tried again and no luck. I then got towed back home but not sure if it was the clutch that went or what exactly it is that happened. I have a feeling it's the clutch but not sure if I need to replace the entire clutch, just the master cylinder, slave cylinder, etc. or if not the clutch at all. Has anyone else had this problem or have any ideas whether its the clutch or some other problem?
post Feb 23, 2007 - 3:32 AM
subpenny127
Joined Jul 30, '05
From florida
i would go ahead and replace the entire clutch. mine did that but not near as bad and i just put a new clutch in and had the flywheel resurfaced and now it runs awesome.
post Feb 23, 2007 - 2:01 PM
95celly
Joined Feb 22, '07
From Philadelphia
what kind of clutch would you recommend putting in? and how long did take you to do it?
post Feb 24, 2007 - 1:10 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Sounds like either your clutch disc or your pressure plate is bad. Good Luck
post Feb 24, 2007 - 10:20 AM
subpenny127
Joined Jul 30, '05
From florida
id go with any of the ones in the parts database and i took it to shop to have it done. took like 4 hours
post Feb 28, 2007 - 12:09 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(bindertch @ Feb 24, 2007 - 6:10 AM) [snapback]529839[/snapback]
I have had nothing but good experiences with multiple [diff cars] with ACT. Cheaper than stock for me too.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:02 AM
