Crazy Engine Swaps I'd Like To Do...., Who's up for a real crazy swap in their Celica? |
Jul 30, 2008 - 4:01 AM |
Enthusiast Joined Feb 18, '07 From So Cal Currently Offline Reputation: 3 (100%) |
hey still been thinking of a mid engine AWD 3s powered celi but what tranny 2 use?
-------------------- Your signature is not allowed on 6GC - Defgeph
Aug 2, 2008 - 4:17 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
hey still been thinking of a mid engine AWD 3s powered celi but what tranny 2 use? There's probably a Porsche transmission that you could use, but I probably wouldn't touch that one. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Aug 2, 2008 - 4:29 PM |
Enthusiast Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) |
how about a 26b rotory with rwd conversion
Aug 4, 2008 - 11:33 AM |
Enthusiast Joined Jun 6, '08 From Hamiltron, Ontario Currently Offline Reputation: 0 (0%) |
those are two of the strangest swap ideas I've heard. You guys should stick with more normal swaps rather than coming up crazy ideas that will render the car barely drive-able and illegal to have on the road. Making a Celica Mid engined would be a good idea.... but the MR-2 exists for this purpose and it would be a lot cheaper to use the MR-2 platform instead. There is a man who turned a 95 Integra into a MR hybrid. However he needed an entire prelude. Aside from welding the front subframe into the back of his teggy, he also adapted the prelude interior to the integra's built a whole bunch of whacky one off parts and used a whole bunch of parts sourced from an MR-2 to make the thing run. It took about a year and a half to complete I think and probably cost him a small fortune. The thing is, he did it all himself.
If you were to pay someone to make a 4WD MR Celica, it would cost you 15,000 - 20,000 at least. HOWEVER, the MR Integra with the prelude V-tec engine is insanity and he gets MAD props for it. However the reason its more reasonable with a Honda is because they only offer 1 MR car and its the NSX. While I'm ranting about seemingly impossible swaps. The 26B. To BUY a 26B alone is roughly $10,000. Combining the rotors is the easy(ier) part, especially if you use 2 oil systems. However to combine the 2 engines you need a custom eccentric shaft and those are expensive. Really expensive. And the car will barely run most of the time because you've done nothing more than combine 2 engines and prayed that it will work. However if you want to buy a 26B it would be far more reliable especially since there are engineering firms out to replicate the 787's LeMans winning engine. They will probably be custom fabricated but they will work perfectly. Okay so hypothetical 26B aside the next problem is length. What's beautiful about the 13B is that its small, just small enough to fit into most crazy swap applications, which means you don't need to cut into the firewall (and therefore make the car illegal to drive on any roads) to fit it. The 26B is even a rough fit into an RX-7 sometimes, especially if you want twin-turbo. Then of course you have to source the rear end from a ST205. I guess the bottom line is money, both are possible really however it might be MUCH easier and less expensive to say... but the car that you're basing the entire swap around. -------------------- (\__/) (='.'=) This is bunny. Copy and paste bunny into your (")_(") signature to help him gain world domination. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:06 AM |
