Coilover Help |
Coilover Help |
Feb 25, 2007 - 12:22 AM |
Enthusiast Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) |
Hey guys just got a set of coilovers installed on my car. I love the look but like everyone warns your ride will suffer and camber will suffer also. My steering wheel is off too. Heres my question, should i go ahead get the cusco mounts or should i try camber adjustment bolts?
-------------------- I'am Reinventing the SLow Lane.....
Feb 25, 2007 - 10:57 AM |
i need some help!!! BUMP!
Feb 25, 2007 - 2:25 PM |
Enthusiast Joined Nov 29, '06 From South Florida Currently Offline Reputation: 0 (0%) |
take it to an alignment shop and get your toe-in/out fixed, then see how canber adjustment they can make
then i'd go and purchase the camber plates and have that done, or you can do all at one time |
Feb 25, 2007 - 3:01 PM |
Your steering wheel is off because after you install new springs/coilovers you need an alignment. As for your camber.. if you have a camber kit then have it adjusted. If not, don't lower it so much. I don't have a camber kit, so I didn't lower my car too much, and I don't have any problem with my camber. Once I get pillow ball mounts I will lower it more. You should probably do the same if you aren't going to be able to purchase them for a while.
This post has been edited by 95CelicaST: Feb 25, 2007 - 3:04 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Feb 25, 2007 - 7:45 PM |
well i will have the money here in the next week or so. So i will proably order the pillow ...install it....then go get an alignment done.
Lo-Fi Version | Time is now: December 2nd, 2024 - 12:39 PM |
