My Upgraded Brake Setup (ST185, ST204, AT200 components) |
Feb 26, 2007 - 12:19 AM |
I've had some people ask me, so here it is...my notes on my recent (well, at the time I wrote this, it was recent ) brake upgrades.
Front Setup Stock AT200 spindles/hubs and backing plates OEM ST185 single-piston calipers, caliper brackets, and unknown pads Brembo ST185 OEM-replacement rotors (part number 25440) Stock AT200 brake lines Rear Setup Stock AT200 spindles/hubs OEM ST185 backing plates OEM ST185 internal e-brake components OEM ST185 e-brake cables OEM ST185 single-piston calipers Satisfied ST185 ceramic brake pads Brembo ST204 OEM-replacement rotors (part number 25162 I think...may have been 25163) OEM AT200 front brake lines For the front, the rotors do not fit without modification. The AT200 hub has a center bore that's 54.something mm, 1mm larger than the ST185's center bore. The rotors will slide on, but they won't go all the way flush against the hub, which is how they need to be. I used a drill with a round sanding bit and bored out the rotors. I think it took approximately ten minutes per rotor. Once I did that, the rotors slid on perfectly. Then the caliper and caliper bracket bolt right up. The stock brake lines do get pulled fairly tight if you bolt them to the strut using the factory short bolt. I found a longer bolt and used several spacers between the strut and the brake line mounting tab to give the brake line more slack. This is a temporary fix, as I'm going to get ST204 stainless steel brake lines soon. For the rears, the ST185 backing plates with the internal e-brake components bolt in just fine. I used the ST185 e-brake cables, with mounted up to the bottom of the car just fine. I do believe I used the cable splitter (that hooks the single cable from the e-brake handle to the two seperate e-brake cables) from the ST185, but I can't remember for sure. Once the backing plates and internal e-brake components are on, I mounted the rotors and adjusted the e-brake mechanisms so that the rotors locked up equally. The rotors go on just fine. Once the rotors were on, the calipers went right on as well and bolt up just fine. I didn't have the ST185 brake lines, so I used some front AT200 brake lines from a parts car, which work just fine. I don't abuse my brakes enough (well, at all typically) to notice a huge difference, but my car does stop plenty well, and the few times I've been on high speed canyon road runs I've had no problems whatsoever. If you've got questions, just ask...hopefully this thread will be helpful. By the way, here are a couple pics...the front is from a few days ago, after a couple thousand miles on the brakes. The rear is from a while ago, and now the calipers are painted yellow (the same shade as the car.)
Feb 26, 2007 - 12:40 AM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
awesome. i love everything about your car. would it be fair to nominate you for the next featured ride?
-------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Feb 26, 2007 - 2:09 AM |
why not st165 2 piston calipers?
Feb 26, 2007 - 10:41 AM |
Coomer, did you ever have st204 rear brakes in there before ? or just the drums to st185 ?
I know they are all an upgrade from the at200, but do you know how much of a difference the st185s are from normal st204 brakes ? also, are you sure the st185 fronts are only single piston ? I thought they were 2 ? your set up looks good, I like it a lot This post has been edited by Batman722: Feb 26, 2007 - 10:42 AM -------------------- |
Feb 26, 2007 - 11:41 AM |
USDM ST185 were only single, JDM used (i think) the same front calipers as the USDM ST165. i found this out while buying a rebuild kit for my calipers i bought here, the guy i go them from got them from a JDM 185 clip he said.
Feb 26, 2007 - 12:03 PM |
The ST185 single piston calipers and larger rotors are supposedly a better performing option than the ST165 dual piston calipers and smaller rotors. I had both sets of calipers and rotors and chose to go with the larger, supposedly better performing option.
From what I've heard, some early ST185s came with the dual piston calipers and smaller rotors, probably because Toyota had leftover calipers and wanted to use them up. My single piston calipers are actually from a JDM ST185. And Batman, the ST185 and ST204 brakes, both front and rear, are very, very similar from what I've read. I doubt there's any performance difference between them at all. -------------------- New Toyota project coming soon...
Feb 26, 2007 - 5:25 PM |
well i'm putting st165 calipers on rotors about the same diameter as ST rotors. currently the calipers are single piston and just a fraction smaller than ST single pistons. in your humble opinion, think it'll make a lick of difference?
Dec 25, 2010 - 9:01 PM |
Do the ST185 Dual Piston front Brake Calipers have the same set of brake pads that come on the SS-III dual piston brake calipers??? I'm currently waiting for measurements from nsxtypeR on the SS-III Dual Piston Brake Pads to see if I can buy the brake pad setup from the ST185 dual piston calipers. The only option for buying brake pads for the SS-III calipers are from Japan and they aren't cheap. At least $180 and up for front brake pads alone!!!
also I've read up and confirmed on the TRD website that the ST165 dual piston and ST185 Dual Piston Calipers use the same brake pads. But the part numbers for the ST185 and ST202 brake pads don't even come close???!! This post has been edited by BonzaiCelica: Dec 25, 2010 - 9:26 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Dec 25, 2010 - 10:32 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
only the earlier jdm st185s came with twin pot calipers. Which are essentially the same calipers as the st165s. Rotors are too small (255mm). I'm sure the ss-III calipers are a different twin pot calipers. because correct if I'm wrong they use the 277mm rotors the st204/202 uses.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Dec 26, 2010 - 1:47 AM |
oh alright then. Yea my guess is that the ST202 SS-III Dual Piston Calipers are better performing than the ST185 and ST165. But I just need the brake pads length, width and height!!
Dec 27, 2010 - 3:31 AM |
Well here it is. Now all I need is the measurements for the ST185 dual piston brake pads please!!!
SS-III Brake Pad Measurements : This post has been edited by BonzaiCelica: Dec 27, 2010 - 3:33 AM -------------------- Group buy to replicate Narrow E series transaxle parts
Dec 27, 2010 - 4:06 AM |
Enthusiast Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
Some more pictures:
SSIII brakepad surface: Sideview of the pad. This one is close to brand new,only done around 1000 km: This post has been edited by nsxtypeR: Dec 27, 2010 - 4:07 AM -------------------- JDM ST205
Lo-Fi Version | Time is now: November 26th, 2024 - 9:56 AM |
