APEXi AFC Neo, on a 96+ (pictures, installation, etc) |
Feb 26, 2007 - 4:05 PM |
Dustin and I put in my SAFC a few weeks ago and just wired it in yesterday
I have not yet messed with any correction settings, nor have I figured out exactly what everything means and what it does. right now its just a 'glorified gauge' if anyone has tested and found the ideal settings for the stock 7A, please share A'PEXi AFC Neo Features include: - Completely new case design - Compact design - Incorporates both AFC and VAFC functions in one unit - 16 point fuel correction - Color FED display - User defined button and background colors - Inverted "anti-glare" screen Key functions include: MONITOR MODE- * RPM * Throttle * Battery voltage * Correction % * Air flow % * Pressure * Karmann * VTEC SETTING MODE- * Air map * Air map graph * Throttle point * Deceleration air * VTEC control * VTEC unmatch ETC MODE- * Model select * Mode select * Car select * Sensor select * Analog scale * Warning set * Display set * Sensor check IN THE BOX: along with an instruction manual, wiring diagrams, and connectors that we didn't use anyway WIRING: on my stock '97 7AFE I looked up the 96+ ECU wiring diagram, the pinouts from a 94-95 are the same but the wire colors are different. If you're installing an SAFC do not go by wire color only, use the wire colors as a guide but make sure they come from the correct pinout on the correct plug. in the 1997 Toyota Wiring Book one of the wire colors is wrong. (Note: this was done on an auto wiring harness plugged into a manual ECU. although I'm pretty sure the pinouts are the same, just some of my wires in the last connector do nothing and those with factory manuals probably won't have anything in those pinouts) ^when to splice or cut and where E5 Connector (26 pin) RPM Signal : pin #3 : BLACK/YELLOW wire on the harness this goes to the GREEN wire from the SAFC (Note: in the 97 Wiring Book it says this wire is Green/Yellow but splicing into that wire will disrupt your IAC and set your CEL. make sure you double check the pinout) GROUND : pin #14 : BROWN goes to BROWN on the ECU side and BLACK on the engine side of the same wire (Note: all the grounds eventually go to a junction connector and become one wire but I used the ground from the specific pinout just in case) E6 Connector (16 pin) MAP Sensor : pin #2 : BLUE to YELLOW on the ECU side and WHITE on the engine side Throttle Signal : pin #11 : BLACK/WHITE to GREY from the SAFC E7 Connector (22 pin) IG Power : pin #12 : BLACK/RED to RED on the ECU side and RED/WHITE on the engine side Power : any wire that gets power with the key in the ACC or ON position : we used the GREY wire from the cigarette lighter INSTALLATION: Theres not really a nice place to mount it so I decided to get rid of the pocket under the radio and devise a way to hold it behind the center console trim. Theres a little ledge on the back side of the center console trim that holds it up perfectly against the bottom of the radio. Its not quite long enough so I still have to figure out a way to cover up the right side but heres the pictures... and the different Monitoring modes are completely customizable, you can choose what you want to monitor and where its displayed: digital (up to 4 channels) analog or a combination -------------------- |
Feb 26, 2007 - 4:12 PM |
so how much did you pay for a cool light show in the car?!
it looks spiffy |
Feb 26, 2007 - 4:19 PM |
haha... too much for what it is right now, but I expect it to be much more useful in the future
Feb 26, 2007 - 4:21 PM |
looks good.. nice write up .
i put my safc in the same spot, but i just used black velcro tape over top of that pocket under the radio. this way, if i need to hide the safc, i can just stick it inside of the pocket and close the door. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 26, 2007 - 4:24 PM |
Enthusiast Joined Feb 6, '07 From england Currently Offline Reputation: 0 (0%) |
looks a lot better than the previous model with the colour display
Feb 26, 2007 - 8:38 PM |
That's got some nice monotoring features on it. I hope it helps the car. I wouldn't mind something like that if the price was right. That would be under $200.
Feb 26, 2007 - 10:27 PM |
Enthusiast Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
I have been saving this link for when i could buy something like this, its an oldy but a goody hope it helps.
SAFCII settings -Aaron- -------------------- |
Feb 26, 2007 - 10:49 PM |
Enthusiast Joined Jul 8, '04 From Durham, NC Currently Offline Reputation: 6 (100%) |
Awesome, I just installed my SAFC II in the GT this past weekend. I'm going to use it for my turbo install but is there any sort of tuning I could do N/A to get a little bit more power ? One thing that I would like to note is that the Map sensor on the 98 GT is also a blue wire, whereas on the 94-95 I believe its black/yellow.
Feb 26, 2007 - 11:05 PM |
QUOTE(afroman @ Feb 26, 2007 - 10:27 PM) [snapback]530670[/snapback] I have been saving this link for when i could buy something like this, its an oldy but a goody hope it helps. SAFCII settings -Aaron- awesome. once I actually understand what I'm doing I'll try some settings in that thread he listed 10 points of correction at the preset RPM. I have to fill in 16 points at my own RPM so I actually need to know what I'm doing -------------------- |
Feb 27, 2007 - 1:54 AM |
dont go by anything in that thread!!!!
he says how he took out 16% worth of fuel and his gauge still ran rich. i was skeptical of how he was monitoring this, and noticed that in his profile that he was just using a narrow band a/f gauge !!!!! hurley, you shouldnt mess with any of the settings without having a WIDEBAND o2 sensor/gauge, or taking a trip to the dyno. you should talk to manny and see if you can book an hour at the dyno he uses and he should be able to do a nice tune with it for you. remember, it may look really cool and be tempting to play with, but its NOT a toy. it could lead to serous engine damage in the wrong hands. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 27, 2007 - 2:31 AM |
Manny's like my adviser, I wouldn't do anything drastic without finding out what he thinks and why first lol
Feb 27, 2007 - 3:45 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Just got my RSM and NEO 2 days before Gonna be installing it in my SS pretty soon. I wasnt impressed of it much then i opened the box... I was actually hopind display of the NEO to be more acurate and brighter, and not looking like a VGA 16 color one... LOL
-------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Feb 27, 2007 - 4:57 AM |
Enthusiast Joined Mar 29, '06 From UK Currently Offline Reputation: 0 (0%) |
QUOTE so how much did you pay for a cool light show in the car?! Haha still a amature..lol (sorry not meant to sound offensive) light show ey???? how bout a visit to the starship enerprise???? This post has been edited by P5ycho: Feb 27, 2007 - 4:58 AM |
Feb 27, 2007 - 6:41 AM |
yea, guys, like art said, i wouldnt go by that guys thread..messing with settings, without a wideband o2 sensor, isnt really a good idea.
you REALLY need to know what your exact A/F ratio is. (not a rich/lean lightshow gauge) pulling out a little fuel up top like he did is exactly what is needed on the 5s, but each individual motor requires its own settings. steff, setting the RPM points is easy, just start @ your idle rpm, and work your way up to redline. with the 16 rpm points, you have 4 more than the SAFCII, which will give you a total of 8 more tuning points. (hi and lo throttle) from me ranting about it to D,lol he should understand the theory behind the unit and how it works...its pretty simple really. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Feb 27, 2007 - 9:30 AM |
I understand the concept I just don't know where I'm supposed to add or subtract things... but I guess thats exactly what the wideband o2 is for. I assume the goal is to make the A/F ratio as stable as possible across the RPMs ?
Feb 27, 2007 - 9:49 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(lagos @ Feb 26, 2007 - 9:21 PM) [snapback]530526[/snapback] looks good.. nice write up . i put my safc in the same spot, but i just used black velcro tape over top of that pocket under the radio. this way, if i need to hide the safc, i can just stick it inside of the pocket and close the door. I did the exact same thing. I fly often so I can put it in the pocket so people don't steal my "Satellite radio" LOL [thats what everyone thinks it is except tuners of course] Does yours not display knock Hurley? I didn't see that in your list of display settings. The display itself and the case are much nicer than the SAFC-II but I don't know if I like any of the actual screen display styles. They should have kept the ones from the SAFC-II. Acouple of them were really nice and easy to read while driving. -------------------- |
Feb 27, 2007 - 10:11 AM |
I don't think it displays knock. if it does I haven't found it yet
Feb 27, 2007 - 4:16 PM |
QUOTE(hurley97 @ Feb 27, 2007 - 9:30 AM) [snapback]530817[/snapback] I understand the concept I just don't know where I'm supposed to add or subtract things... but I guess thats exactly what the wideband o2 is for. I assume the goal is to make the A/F ratio as stable as possible across the RPMs ? the goal is to take out enough fuel, to where the car is running leaner and making more power, but still totally safe. running too rich or too lean will rob you of power. the idea is to find the perfect balance. that can really only be done right on the dyno. now the question of where that perfect balance is, will depend on what type of gas you fill up with. the higher the octain, the leaner you can go while keeping the motor safe. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 27, 2007 - 5:22 PM |
QUOTE(hurley97 @ Feb 27, 2007 - 10:11 AM) [snapback]530828[/snapback] I don't think it displays knock. if it does I haven't found it yet it should..the SAFCII did, i would assume the NEO does... :::EDIT:: just went over the instructions super quick.. so it DONT display knock...BOOOOOO not that its a huge tuning tool, but i did kinda like that on the display with the SAFCII -------------------- Former Team 5SFTE pro member ;)
Feb 27, 2007 - 7:26 PM |
neo was the jump to bring the v-afc and the s-afc together.
it looks better :\ nice write-up -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 8:27 PM |
