WTB 7A rods and 4AGZE pistons, found some (Dlete plz) |
Feb 26, 2007 - 9:47 PM |
Enthusiast Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
Like the topics says, i would like to buy some 7AFE connecting rods.
Also if there are some low-comp 4agze pistons out there with a 20mm wrist pin ill buy those too if they are the right price -Brian This post has been edited by Celiracer18: Mar 1, 2007 - 3:15 PM -------------------- -Brian
Feb 26, 2007 - 10:19 PM |
if you're going for what I think you're going for you may want to get the stronger Pauter rods
and if you find a good place to get some new or used 4AGZE pistons post it up, I'd like to know too -------------------- |
Feb 26, 2007 - 11:19 PM |
since i dont have the $750 for the pauters i plan on just shotpeening the stock rods till my wallet isnt empty ill keep on looking tho
Feb 26, 2007 - 11:33 PM |
Enthusiast Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) |
sorry to clatter up your WTB thread, but i was wondering if the 4age cams and spring kit that this site has would fit on a 7afe head? clicky
-------------------- 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
Feb 27, 2007 - 10:19 AM |
they probably wont because of the way the heads are designed. IE the 7a has a slave cam design and the 4A has 2 seperate cam gears.
Feb 27, 2007 - 12:15 PM |
I can probably hook u up with the rods...or the entire motor lol
Feb 27, 2007 - 5:32 PM |
Enthusiast Joined Feb 6, '07 From england Currently Offline Reputation: 0 (0%) |
is there anywhere that cams for the 7a that are availible or reccommended regrinds that are better
Feb 27, 2007 - 5:56 PM |
QUOTE I can probably hook u up with the rods...or the entire motor lol you've got PM -------------------- -Brian
Feb 28, 2007 - 11:43 PM |
BUMP!! cant find a set of these pistons anywhere
Mar 1, 2007 - 2:19 AM |
Just FYI... 4AGZE pistons won't lower compression in a 7AFE, (yes in a 7AGE hybrid) nor will they fit the 7A rods without modifications. The 7A rods have the pins pressed into the rod. The 20mm wrist pin 4AG's have the pin pressed into the piston. The 7A rod will require machining...
This post has been edited by Kwanza26: Mar 1, 2007 - 2:20 AM -------------------- "It's ok to be naked girl... I'm an artist!"
Mar 1, 2007 - 8:07 AM |
Enthusiast Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
I've got some 7afe rods and pistons, PM me if interested. Out of aan oil burner but the pistons and rods are good. Cheap for all 4! $15
Lo-Fi Version | Time is now: November 30th, 2024 - 2:05 AM |
