> Exhaust for a 3sgte swapped celica, Anyone tried this yet?
post Feb 28, 2007 - 8:48 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I was considering buying this bolt on exhaust. I called the company and they said it is a direct bolt on for a st205. Im not sure if it would bolt onto a st204 with a 3sgte or if there would be problems. Its a cheap price for a stainless steel exhaust. I was hoping someone had some insight before I drop $350 on this exhaust. thanks
ebay
post Feb 28, 2007 - 9:24 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
try it and let us know tongue.gif i don't see why it wouldn't it might be slightly off because it runs along side the drive shaft on a st205 but on the st204 it shouldn't matter. :shrug:
post Feb 28, 2007 - 9:34 PM
robdrummer
Joined Dec 1, '04
From Pittsburgh, PA
just make a custom one or have someone weld it for u
post Feb 28, 2007 - 9:47 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
I don't think that will fit anything but a ST205. If you compare it to the one Dr. Tweak had fabbed for us you'll see how it bends differently around the rear axle/a-arm unlike the one on our car:
post Feb 28, 2007 - 11:07 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I think it may fit. It seems that yours is bent more. But if you compair them side by side it seems they are routed in the same place. If nothing else I can use the flex and center pipe and have the muffler welded onto another section to make it fit. Its worth a shot! Ill let you know but itll be a few months. I gotta get the money together. Later
post Mar 1, 2007 - 2:01 AM
phattyduck
Joined Dec 5, '05
From LA, CA
The ST205 is completely different from the ST204 from the gas tank to the back of the car.... You *will* have to modify it to get it to fit, and it would probably be cheaper to go fully custom.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Mar 1, 2007 - 11:05 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Do not buy SSautocrap! The stuff is made from inferior [thin] metals and it will most likely break. Also they will not answer your calls or call you back. For that money you could have one made at a local muffler shop that is custom fitted to your car and your specs.
Lo-Fi Version Time is now: January 9th, 2025 - 11:11 PM
