> 6gc members with doggys triple gauge pod
post Mar 1, 2007 - 12:28 AM
AllTrac96
Joined Jan 23, '05
From Portage
my gauges don't fit they sit too deep and rub the dash. id like to know what gauges all of you are using. thanks!
post Mar 1, 2007 - 12:32 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Autometer nexus. Had to wrap the gauges in tape to pressure fit them, and they fit like a champ, no dash rubbing. Make sure you're positioning the pod far enough forward too.
post Mar 1, 2007 - 5:12 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE(Fastbird @ Feb 28, 2007 - 10:32 PM) [snapback]531573[/snapback]
You have to position the pod far enouth from dash. I used 3 different types of gauges installing the pod and all of the fitted fine. I used SLM gauges, AutoGauge, and DW gauges.
Heres how the SLM gauges fit and look:
<<<<<< DCw / JDMart >>>>>>>
post Mar 1, 2007 - 12:15 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
QUOTE(doGGy @ Mar 1, 2007 - 5:12 AM) [snapback]531626[/snapback]
Thats Sexy
post Mar 2, 2007 - 8:12 AM
super13jew
Joined Oct 13, '06
From palmetto,FL
whats the actual name of dw gauges?
post Feb 17, 2011 - 11:04 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
i have this doggy's triple gauge pod sitting in my trunk. I have an n/a engine. The only thing I would need to monitor would be oil pressure, oil temperature, and voltage, because I plan on running a small lightweight battery. What do you think thats all I really need right???
post Feb 18, 2011 - 12:15 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (BonzaiCelica @ Feb 17, 2011 - 8:04 PM) *
You dont really even need that unless your going for looks. Turbos run gauges because if your pressure or temp goes up or down even a little your turbo may get fried, with a NA if doesnt matter because the light will come on when the pressure is low, and the temp is usually fine. Voltage however is a great gauge, i bought a little electric unit that shows the time, outside and inside temp, and my voltage all on one screen, and its fairly accurate as well.
This post has been edited by SupraKid: Feb 18, 2011 - 12:16 AM
post Feb 18, 2011 - 3:10 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (SupraKid @ Feb 18, 2011 - 1:15 AM) *
oil pressure is probably not necessary haha I see what your doing here Andrew your just pointing out things So i can sell you my gauge pod.
yes as I said voltage due to the fact that I will be getting a small battery, and Oil temp for when I go to the track with my 99 gt celica muahaha. So I just might sell it to you Andrew just maybe.
post Feb 23, 2011 - 2:43 AM
azn87
Joined Aug 2, '06
From bay area
how did u guys mount the guage pod holder down to the dash
post Feb 24, 2011 - 5:26 PM
richee3
Joined Jun 29, '08
From Denver
Double sided tape.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 26, 2011 - 11:11 PM
azn87
Joined Aug 2, '06
From bay area
has anyone tried velcro????
post Feb 26, 2011 - 11:51 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (azn87 @ Feb 26, 2011 - 8:11 PM) *
I think it would be to thick and noticeable..Why use Velcro? Its more expensive and you cant exactly just detach your gauges haha.
post Feb 27, 2011 - 12:37 AM
azn87
Joined Aug 2, '06
From bay area
I'm also doin hella crap to my radio so I would need to get the center part off an on
post Feb 27, 2011 - 12:43 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
The gauge pod sits on the dash though? And double sided tape doesnt weld it to the dash haha.
post Feb 27, 2011 - 3:07 AM
azn87
Joined Aug 2, '06
From bay area
but i would have to replace the tape almost everytime i take the guages off
post Feb 27, 2011 - 3:10 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
Do you plan to take them off on a regular basis? Cause then id recommend not getting this type of pillar haha.
post Feb 28, 2011 - 3:59 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (doGGy @ Mar 1, 2007 - 12:12 AM) *
I want those!
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Lo-Fi Version Time is now: November 26th, 2024 - 8:52 PM
